Question about HP Officejet Pro L7580 All-In-One InkJet Printer
HP L7580 My new printer prints fine from my PC all programs but sends and recieves faxs very faintly. I cannot read them however as stated it prints perfect from PC. I don`t know much about these things but is almost as though it has a problem scanning and recieving. Any Help Please ?
  • 85 Answers
Read manual cearfully and follow the instruction in it. if it is also new one u can contect your supplaer of printer to solve the problum
Posted on Jun 03, 2008
Can I send and receive faxes?
u need to have a modem that can send receive fax, then install faxing software in computer, install dell drivers then setup modem, and send recieve program, to send fax u scan n save then use fax program to use image sometimes it may scan and send at same time? read manual with program
Aug 22, 2015 | HP Photosmart 3210 Printer
I keep getting error message 388 whenever I fax to any number. I have been able to receive faxes. My all in one is an HP officejet pro L7580
You probably need to run the fax test to check if the fax mechanism is working fine.
Click on Setup Button ( ranch like symbol ) on the printer front panel.
Scroll down till you find Tools ( press ok )
Check for Run Fax Test ( Press OK )
It will print the test results and everything should pass.
To solve your fax issue, follow the steps below.
Check for Advanced Fax Setup ( or Basic Fax Setup ) - Press OK
Look for ECM ( Error correction mode ) - Press OK
Turn the ECM OFF
Try to send fax. It Should work.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 16, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
When you change the print heads for a Hp L7580 what problems does it resolve?
Replacing the print heads fixes any poor print quality you are experiencing. Typically people replace print heads when a certain color (most likely black) is printing very faint or streaky. Over time the nozzles in the print head can get clogged with dried up ink. Enough clogged nozzles will inhibit ink from being deposited on the page in certain areas.
Feb 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
WHY DO I GET A BLANK PAGE AFTER EACH FAX?
The fax machine that is sending you the fax may be also sending a confirmation page that is not needed or compatible with your machine.
I have an older machine that prints a confirmation page after each fax. People on the other end sometimes receive a blank page after each fax that I send them while my machine prints a mostly blank page with only a single line of text at the top with the date and time.
Feb 01, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
We don't seem to be able to recieve faxes
Phone Co ran a check and it was due to bad fax line so they fixed it.
Jun 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP C6180 prints but won't copy or fax...
i can not recieve faxes. It use to work fine. I can send them out, but not receive.
Jan 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp Officejet J5780 All-in-One
On the Officejet`s control panel, Press Setup, then press 2, now press 3.
The panel will display the choice of Off, Print confirmation on Send, Print confirmation on recieve or Print on Send and Recieve. Select your choice.
Oct 19, 2008 | HP Officejet J5780 All-In-One InkJet...
HP Officejet pro L7580 printhead error
This is an old thread - but I encountered the same problem with my 7580 today - and found this thread. I had replaced an empty black ink cartridge with a new XL black one. I made a about 4 or 5 mostly black and white prints and just like that it told me both printheads had a problem. Took them out and cleaned each ink head with toilet paper and replaced them a couple of times. Then it said that only the M/C head was bad. I tried to do various diagnostics and print head cleaning from the Solution Center with nothing happening. I took out the M/C head and shook it a few times and wiped the head with a napkin. Then I took some methylated spirit and wiped the head again. Inserted, closed the cover and pressed ok for a couple of seconds. It then proceeded to do all that I tried to do from my PC - print test page, print diagnostics page, and align the heads. It went through all and printed fine. This saved my about at least US$80 for one printhead! I hope this helps others. This was posted on 10Jan2011 and applies to HP 88 printheads.
Apr 28, 2008 | Office Equipment & Supplies
New hardware, old computer?
Do have dial up modem if Yes you can use to send a fax from ur computer using the "Lexmark Fax Solutions".And the connection should From the wall jack to the computer dial up modem line in and Computer should be on o recive fax and to send Fax..If You have DSL modem you cannot send or receive faxes you need special setup...
for Fax set up please this link : http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS25296&relevance=1
Oct 29, 2007 | Lexmark X5470 All-In-One InkJet Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
88 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
