Question about Tag Heuer New Aquaracer Alarm WAF111Z.BA0801 Watch for Men
I have a tag aquaracer alarm, how do I set the alarm?
5 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
escapement
  • 2334 Answers
SOURCE: My TAG Aquaracer bezel moves counterclockwise
Yes, there are solution for that, but you will not be able to solve it yourself as the new part is needed.
That new part is called BEZEL SPRING and it is fitted underneath the bezel.
Bezel spring has special hooks pressed into it and allows to turn the bezel one way only (anticlockwise), at the same time stopping the bezel to turn clockwise.
Another cause can be that the dirt and grime are collected between the bezel and the watch case (this is where the bezel spring is located) and is stopping functionality of the bezel spring by leting the bezel slide over the hooks. This can be fixed by cleaning the watch case in ultrasonic cleaner.
Anyway- if the bezel is rotating on its own, I suggest that the bezel spring is broke and you will need to replace it.
Do not forget to rate, please.
Posted on Feb 10, 2009
  • 2501 Answers
SOURCE: I HAVE A TAG HEUER
I presume you no longer have the instructions, so I explored the Tag web site and they do not appear to offer an option to download instructions for your watch.
The only thing I can suggest is that you go to your nearest dealer and ask for help. You can find out where your nearest dealer is by going to the TAG web site "tagheuer.com". select one of the watches and on the right of the screen you will find a menu which includes "find your nearest retailer", who will be able to help.
Posted on Jan 13, 2010
ginko
  • 19396 Answers
SOURCE: Hello guys My new Tag Heuer
Hi.
Ensure that your model has an Alarm. Not all Tag Heuer chronographs have the alarm function. If there is alarm function, try resetting the clock by setting the hands on zero and setting time and date again (see here: User Manual ).
If there is alarm, and this does not beep when programmed, then it is not a matter of switching it on and off. The alarm is always switched on when you program the alarm time.
Weak battery can cause the problem, but the watch is new (battery lasts approx. 2 years). If you want to test a replacement battery have the job done at a Tag Heuer authorized shop. DO NOT replace the battery by yourself. Tell them that the watch is new and in warranty. If that does not fix the problem, ring immediately Tag Heuer, the watch may be defective.
Try also contacting Tag Heuer. See:Contact us - TAG Heuer.
Regards.
Ginko.
Posted on Dec 28, 2010
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Tip
    TAG HEUER Aquaracer quartz chronograph manual.
    Follow this link and download original TAG HEUER Aquaracer quartz chronograph manual: http://www.tagheuer.com/the-collection/aquaracer/man/quartz-chronograph/index.lbl?w=CAF1110.BA0804
    on Feb 09, 2010 | Watches
    I need to stop alarm on watch MSP74576W
    Hold right bottom button and then press right top button, while looking at tge watch face, this will toggle a little AL display indicator over the minutes digit
    Mar 07, 2014 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
    What type of battery does the aquaracer used?
    Just replaced a women's Aquaracer battery. It's a 364. Get the SR (silver oxide type) as it will last longer.
    Jan 30, 2011 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
    Hello, my new Tagheuer aquaracer calibre 5 500m
    I have the same problem with mine....They have some kind of manufacturer malfunction , tag will not admit. My is in the shop for the 3rd time ...at this point they should replace my watch...this one is a lemon.
    Jul 28, 2010 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
    Do any Tag Heuer Aquaracers have serial numbers like "abc1234"?
    Yes they do;
    To see this go to the TAG web site "tagheuer.com" and select "watches".
    Now select "aquaracer" and you will see a list of variations.
    Jan 16, 2010 | Watches
    I HAVE A TAG HEUER AQUARACER ELECTRIC WATCH (BATTERY OPERATED) THAT HAS AN ALARM FUNCTION THAT I CANNOT SHUT OFF. IT GOES OFF EVERY DAY. HOW CAN I STOP THIS?
    Jan 12, 2010 | Tag Heuer 2000 Aquaracer Chronograph...
    I am unable to return to the 0 crown Position - TAG-CAF2112
    The aquaracer has a 'screw-down' crown.  This means that the crown needs to be screwed in the reset it back to the 0 position.
    Jan 09, 2009 | Tag Heuer Aquaracer CAF2112.BA0809 Wrist...
    Tag Heuer New Aquaracer Alarm WAF111Z.BA0801 Watch for Men Logo
    131 people viewed this question
    Top Tag Heuer Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
