Question about RCA TruFlat 27F520T 27" TV
On my tv there is lines on the top about 4ins from top is my tv going or could it be fixed
    Top Expert:
  • RCA Master
  • 75,304 Answers
This fault can be fixed. it is vertical output section problem inside on your TVs circuit board. Please consult with any experienced technician.
Posted on Oct 17, 2010
No picture used to have lines at the top
It could be your current problem, but it is not the problem causing the lines.
You can send the main board to us and we can test it and see how it behaves, possibly fix it, but we likely won't be able to take care of those lines.
Feb 24, 2014 | Sanyo DP46848 LCD TV
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
There a multi colored lines across the entire screen how can i fix this? you can see the TV on.. behind these multi colored lines... very faintly.. please advise how this can be fixed.. chris trizano-...
Hello; Not much info given. Are the lines from top to bottom? , and does EVERY line go fully from top and bottom. If the lines don't go FULLY from top to bottom, you have a cracked LCD panel ( cost more than TV sold for ). If they all go fully from top to bottom, It can still be the LCD panel OR the LCD controller board ( much less expensive ) John
Dec 19, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Lines at the top of both my Symphonic tv's
You have a vertical deflection issue on both. Sounds like a bad capacitor. This repair is tricky but not expensive. Have a shop check it for you. Thanks for using fixya.
Feb 28, 2010 | Panasonic CT2722H TV
Screen has 2ins line across it at 4ins from bottom
COULD BE A DIRTY CABLE CONNECTION TO THE Y-BUFFER BOARD, OTHER WISE YOU WILL NEED TO REPLACE THE ENTIRE SCREEN, VERY EXPENSIVE REPAIR
Dec 29, 2009 | Samsung PCN5425R 54" Rear Projection...
Where transmission fluid dipstick tube on a 2005 pontiac G6 GT
alot do not have a dipstick jack car up and block as u need to go under car on front of trans is a plug about 4ins. up take out and fluid should come out
Apr 19, 2009 | 2007 Pontiac G6 GT Convertible
Hi i have a toshiba 32wlt68 lcd tv the telly is superb but it as picked up a fault with the scren.It has got vertical lines down the screen about 4ins apart i have tried everything and they just wont go....
Possibly try a new scart lead.Try and get a gold plated connection.Around 15-20 quid. The pins inside the scart tend to loosen after a few years and if just one is'nt connecting properly it can cause picture loss
Oct 25, 2008 | Televison & Video
Vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
Dec 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black vertical lines is there a fix
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Oct 27, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Panasonic tv has white lines at top of screen
suspect it's 1 or a couple of bad capacitors in the vertical deflection circuit the caps are in the 400 series, c400,c401,c402, etc... check or replace c414,c418 & c417
Aug 30, 2006 | Panasonic CT2722H TV
RCA TruFlat  27F520T 27" TV Logo
88 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
