Question about Briggs & Stratton Garden
Briggs and statton sprint xp40 lawnmower engine running rich how do you adjust mixture
3 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Briggs and Statton Sprint Lawnmower engine 3 years
Hi
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 19, 2011
SOURCE: Fuel mixture appears to be too rich on myHonda lawnmower
There is an air/fuel ratio adjustment screw on the side of the carburetor. Turn this back and forth until the mower runs smootly.
Posted on May 04, 2009
Craftsman model 917289031 acts like its loading up and backfires while mowing any ideas ?
Sounds like a engine tuning problem.
Mixture too rich under load .
If you have a briggs and stratton engine you can probably find help at this site.
Manuals Parts
tuning four cycle lawnmower engine YouTube
Sep 10, 2014 | Garden
Briggs instructions
Locate the drain plug on the bottom or side of the engine (might have a drain pipe attached to it) remove plug let oil completely drain screw off filter and replace (if equipped) refer to manual or Google and find out how much oil the engine holds (maybe around a quart) replace oil check for leaks and go mow your grass
Aug 15, 2014 | Briggs & Stratton Garden
Illastrated picture of 6.75 briggs and statton lawnmower engine to identify parts
go online to briggs and find there parts manual for that engine and print it
Dec 07, 2011 | Briggs & Stratton Briggs Stratton...
How do i replace a pull cord on a b&s 3.75 sprint lawnmower?
it is a small engine just buy a new one it will be cheaper in the long run and save yourself some trouble
Jun 12, 2011 | Briggs & Stratton Briggs Stratton...
Mower running to rich,need to adjust down fuel mixture,when mower is running out of fuel it runs better
Is this on idle, fast speed or both? From what I read adjust the high speed screw clockwise in small increments and see if that is better, what this does is lean the mixture. You don't want too lean a mixture as this could eventually damage the engine, so adjust the needle back and fourth until you get the engine running good. Once it is running just right turn it back 1/8 to 1/4 turn to make sure it is not too lean. If the engine stumbles when going to high speed adjust the low speed needle until the motor goes to high speed without missing, or hesitating. Hope this helps.
Nov 22, 2010 | Briggs & Stratton Garden
Ok i have a problem with my Briggs & Stratton 16HP v-twin vanguard engine.When i start the engine and rev it up when i idles back down it sits there and rev's up and down then it straightens out and...
It appears that you have a slight mis-adjustment in the idle speed and idle mixture. To adjust setup, start with at least a half tank of fuel, and have engine at operating temperature (That is warm but not overly Hot). The Briggs & Stratton Website manuals section should show the locations of the adjusting screws if you are not sure of them.
To adjust idle speed set Throttle control to minimum and adjust screw on throttle butterfly to maintain a good idle speed. To adjust idle mixture, screw in idle mixture screw (Lean) until motor falters and then screw out (Rich) until it falters again. Correct setting is the halfway point of these two positions. You may have to re-adjust idle speed again and also the mixture to get best running.
If you are not comfortable doing this, take it to a B & S dealer.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a Briggs and STatton 24 OHV intek motor on a craftsman lawn tractor. I got it on sale and when I got home it ran rough. The fuel line had collapsed or was plugged with some white powder. I took off...
It sounds like the fuel mixture is running very Lean..There are usually two adjusting screw screws on the carburettor that control the mixture. A Larger one is for the Main Jet and a smaller one for the Idle Jet. There is also an adjusting screw on the throttle butterfly to control the idle speed.
To adjust setup, start with at least a half tank of fuel, and have engine at operating tempurature (That is warm but not overly Hot). As a starting point, loosen (anticlockwise) Main Jet screw about half a turn, to richen mixture,so that engine will run without choke. Run engine at full speed and adjust main jet for highest smooth speed without engine missing due to mixture being too lean or rich.
Allow engine to idle and the adjust Idle Jet Screw for smoothest idle. Idle Speed screw may have to be adjusted if idle speed is too high/low.
Sequence above may have to be repeated to get best running. If engine hesitates sometime when sudden load is applied but then picks up, try adjusting Main Jet by 1/8 to 1/4 turn richer until it handles the load without faltering.
Aug 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
B and s sprint xp40 29kg 2006 self propel
generally the belt gets stretched so check that 1st to see
Jun 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Ihave a tank mounted carby type Briggs and Statton
it should be right below the link to the choke rod
if not what is the engine number
Mar 07, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
May 04, 2009 | Garden
Garden Logo
714 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
