Question about Sony Playstation 3 (PS3) Console
My PS3 has been broken for a very long period of time. About 6-9 months now, I've lost track. Every time I turn it on my PS3, it starts with the wavy animation and the colored background, and then the PS3 trademark fades onto screen on the right side on my TV. (This is what it's suppose to do)But after the PS3 trademark disappears from my screen, it stays on the wavy colored background. No icons or arrows, nothing appears except for the wave animation. The background is still moving after the trademark leaves too, so the PS3 didn't just freeze. When I press or hold down the PS3 button in the middle of the controller, it doesn't do anything but turn the controller off. I just now tried it a few times before I contacted you but nothing has changed. Please, help me Dillon Hancock
    President:
  • 1,139 Answers
Ok, please try the following steps :
Step 1. Turn your PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep a total of 3 times and turn off again. Release the power button.
Step 3. Press and hold the power button. It will beep when you first press it, then 5 seconds later it will beep again and then it will beep twice quickly. Let go of the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this then continue to the next step
Step 5. The PS3 will load with a menu with 6 options, choose number 5 "Restore PS3 System" and follow the on screen prompts.
Using this method should sort your PS3 out for you.
Hope this helps
Posted on Oct 16, 2010
How Accurate Are Period Tracking Apps?
Period Tracking apps and websites that aim to figure out which days a woman is most likely to conceive may not be very accurate, according to a new android and smartphone apps that offer to predict a woman's "fertility window," or the days during a woman's menstrual cycle when she can become pregnant. So for my opinion is that to install Period track app on your phone. It helps you a lot. It is free and easy to use this app. Period Tracker logs your dates and calculates the last average of your past 3 months menstrual cycle to predict the start date of your next periods. I am using this app. I hope you will also like this app after using it.
Jan 19, 2018 | Cell Phones
Tip
After reading SteveGorak's experience, I placed the vacuum end of my...
Hello
This is a tip explaining how we can try to resolve a lens error.
Firstly you will need to understand what exactly the lens error is, and how it came to happen.
The most common cause for a Lens error:
  • Misaligned Lens rings
  • Sand and grid wedged in between the lens and the barrel.
  • Dropping the camera
  • Ran down battery
Here is the Fix:
  • Batteries
Firstly you can try removing the batteries and replacing it with a new set of fully charge ones(2500mah).
  • Memory card
If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed.
  • USB cable
Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in.
  • Barrel Guide Pins
Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit.
  • Compressed air and Vacuum
Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to **** out the particles.
The following Fixes will be done at own risk and can even further damage you camera.
  • Tap your camera with the palm of your hand a couple of times to displace the lens into the original position, or to dislodge particles in the lens barrel.
  • Try gently pushing/pulling/wiggling the lens while powering up the unit.
I hope this can help you to resolve this problem, and send you well on your way to experience that Legendary Kodak moment.
Kind regards
Andrea
on Sep 06, 2011 | Cameras
Konica minolta buzhub c360 giving error c1183
Elevate drive malfunction
<When FS-527 is installed> • During downward movement, the tray 2 upper limit sensor (PS24) is turned OFF and the tray 2 lower limit sensor (PS21) is turned ON. • The elevate motor (M15) lock signal remains set to H for a set period of time while the elevate motor (M15) is turning. • The tray2 upper position switch (SW2) is turned ON even after the set period of time has elapsed while the elevate motor (M15) is energized. • The tray2 lower position switch (SW3) is turned ON even after the set period of time has elapsed while the elevate motor (M15) is energized. <When FS-529 is installed> • When the exit tray is moving up: When the tray up/down motor (M2) starts rotating with the output of the tray lower limit sensor (PS6) being ON, PS6 is not turned OFF even after the set period of time has elapsed. • The paper surface detect sensor/1 (PS2) or the paper surface detect sensor/2 (PS3) is not turned ON even after the set period of time has elapsed after the tray up/down motor (M2) starts rotating. • When the exit tray is moving down: The tray lower limit sensor (PS6) is not turned ON even after the set period of time has elapsed after the tray up/down motor (M2) starts rotating. Remedy When FS-527 is installed: 1 Check the connector between M15-FSCB PJ4 for proper connection and correct as necessary. 2 Check the connector between PS21-FSCB PJ21 for proper connection and correct as necessary. 3 Check the connector between PS24-FSCB PJ16 for proper connection and correct as necessary. 4 Check the connector between SW2-FSCB PJ3 for proper connection and correct as necessary. 5 Check the connector between SW3-FSCB PJ3 for proper connection and correct as necessary. 6 Check the connector of M15 for proper drive coupling, and correct as necessary. 7 PS21 I/O check, sensor check. 8 PS24 I/O check, sensor check. 9 SW2 I/O check, sensor check. 10 SW3 I/O check, sensor check. 11 M15 operation check. 12 Change M15. 13 Change FSCB.
When FS-529 is installed: 1 Check the connector between M2-FSCB CN12 for proper connection and correct as necessary. 2 Check the connector between PS6-FSCB CN5 for proper connection and correct as necessary. 3 Check the connector between PS2-FSCB CN4 for proper connection and correct as necessary. 4 Check the connector between PS3-FSCB CN4 for proper connection and correct as necessary. 5 Check the connector of M2 for proper drive coupling, and correct as necessary. 6 PS6 I/O check, sensor check. 7 PS2 I/O check, sensor check. 8 PS3 I/O check, sensor check. 9 M2 operation check. 10 Change M2. 11 Change FSCB.
Apr 12, 2016 | Konica Minolta Office Equipment & Supplies
Nordic track troubleshoot
Seem like you're running the controller too hot. If it runs ok when no one is on it, your walking belt and deck is probably bogging down causing over current
Jan 06, 2014 | Exercise & Fitness
Tracking issues with SONY XAV60
If you smoke or it is dusty in the car, cleaning the laser lens may help. At any rate, if you are careful, cleaning the lens won't harm anything.
Feb 24, 2012 | Sony XAV-60 Car Video Player
Hello. I'm having a little problem... I have an White-Westinghouse split-type air conditioner (model WSA12PTGMA). The problem is i've lost the user guide manual... and now (after a long period of...
The unit is low on refrigerant and the freeze sensor is shutting the unit down... if you reset it is will wait for the 15-20min to time out before it shuts down again...
heatman101
Jun 20, 2011 | Electrolux Heating & Cooling
Ps3 will not pull in cd
yes there is another fix what happen is that someone try to put a disk inside and then pulled the cd out but too late because the gears inside the ps3 they started to pull the cd and move from there original location ok let's start turn your ps3 and once you see the main menu hold your finger in the eject switch for about 5 seconds or untill the ps3 blue light starts to blink for a long period of time they should blink for about 30 seconds or so this will reset the bluray drive and returns the gears to there normall location let me know if this fix your problem thanks
Mar 13, 2009 | Sony Playstation 3 (PS3) Console
Setting time and date
From the manual:
1. Press the MENU button to open the menu.
2. Turn the SET dial to select [SYSTEM] and press the
SET dial.
3. Turn the SET dial to select [T.ZONE/DST] and press
the SET dial.
4. Turn the SET dial to select the setting option that represents your time zone and press the SET dial. To adjust for daylight saving time, select the time zone with the * next to the area.
5. Turn the SET dial to select [D/TIME SET] and press
the SET dial. The year display starts to flash.
6. Turn the SET dial to select the year, and press the
SET dial.
• The next part of the display starts flashing.
• Set the month, day, hours and minutes in the same way.
7. Press the MENU button to close the menu and to
start the clock.
Jan 15, 2009 | Canon Video Cameras
LED Power light turns on, but nothing happens
If you've only had it 6 months then I would suggest you contact the manufacturer for a warranty replacement. Their warranty period is 1 year so see what they can do.
Mar 15, 2008 | Disney Pix Max Digital Camera
Matsui 42" plasma TV
hi everyone, well i,ve solved our problem. i had the same head bashing problem for months,tried everything.what you have to do is turn all display settings to 0 and then run tv for several hours like that,then slowly bring up brightness and colour only leave contrast at 0. i,ve tested this for a week now and bingo the light show is over at last,my god the relief.good luck everyone
Sep 03, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Sony Playstation 3 (PS3) Console Logo
210 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
