Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
After running for 15 minutes, the windtunnel vacuum cleaner shuts off. It will not restart until it has been off for 30 minutes. Could it be overheating for some reason. All of the filters are clean; the dust tank is empty; the belts have no cracks.
    President:
  • 1,140 Answers
It's not necessarily overheating, but the thermal-fuse is definitely tripping and it takes 30 minutes to reset. There are several causes of this (in most common order):
1. A blockage in the suction system or a full dust tank
2. Dirty filters (Don't forget to check the air outflow filter at the back)
3. A worn belt
4. A faulty thermal fuse.
5. A faulty motor
As you've stated that the dust tank is empty and the filters are clean (don't forget to check the HEPA / air outflow filter at the rear), let's look at the other options.
Check the suction is good by putting your hand over the end of the hose and seeing if it will stay attached to you hand upside down.
Next, check the belt isn't slipping. Lie the hoover on it's side and check the rollers are turning constantly and at high speed. This isn't foolproof as it doesn't account for the extra friction of the brushes on the carpet, but it's a reasonable test. A worn belt wont necessarily be cracked. It can stretch and slip without cracking. Also, when a belt is slipping, you can usually smell burning rubber.
If the hoover runs ok for 15 minutes and there is no burning smell from the motor, then it's more likely a faulty thermal fuse than the motor itself. They are replaceable but unfortunately, thermal fuses aren't always sold separately and sometimes you have to buy a new motor (!!) to get a new fuse. Hoover are one of the best manufacturers when it comes to buying spares, so you might be in luck.
I've removed faulty thermal fuses from vacuums because a spare wasn't available without buying a motor. However, I have always done this with the owners full consent after explaining to them that a safety feature has been removed and they should avoid using the vacuum for prolonged periods without letting it cool. I also test the rest of the vacuum fully before returning it.
If you want to try removing yours, it will be attached to the motor with simple spade connections, but you do this AT YOUR OWN RISK. The danger in doing this is that the motor will burn out if it gets too hot, rather than being switched off by the fuse.
Posted on Oct 16, 2010
It was working fine and them just stopped it is not that old and was not making noises HELP!!
Vacuum cleaners have electric motors in them that require proper airflow to pass over them to keep them cool. Many vacuum cleaners have a thermal (heat) sensitive shut off mechanism built in. This mechanism should prevent the burn out of the motor. If you run a vacuum too long with a clogged hose or clogged filters (especially bagless vacuums) or clogged bags, that is essentially choking the vacuum for air and not allowing it to breath properly. This will cause it to overheat and shut down. Most of the big box store purchased vacuums have very thin wires in the motor windings and can only do this a few times before the motor completely fails. If your vacuum has been shutting down, then cooling off and restarting after about 30 to 45 minutes, then shutting down after only a few minutes of use, your machine is probably clogged up or the filters are compacted.
Jul 05, 2011 | Vacuums
Why does my vacuum cleaner quite working about two minutes into vacuuming? It just shuts off. I have the pet fur picker upper version
Sounds like overheating of motor operating a thermal cut out ..Clean all filters you can run machine with no filters fitted to try if okay first.....
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Shuts down after 10 min use
I would clean or replace filters on it check the hose to make sure it is not blocked . It sound like it is over heating and making the breaker kick off and after it cools down it resets this is caused by dirty filters or blocked hoses.
Feb 22, 2009 | Hoover U5753-900 WindTunnel Bagless...
Windtunnel shuts off after a few minutes of use.
yes i think i can help. all new hoovers have a thermal motor senser that turns the motor off wen it heats up to a certain point mine hade the same problem so i toke it apart and the bering in the motor was worn and heating up and tripping the senser if u have wd40 put some on the bering and be shure to wipe excess wd40 off so it doesnt get in the wires.
Feb 03, 2009 | Hoover U5450-900 Windtunnel Supreme Bagged...
MY CLEANER CUTS OFF
Check that the bag is not full, check that is not a broken contact in one of the wires.
Jul 13, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Hover mach 4 vaccum
usually caused from being plugged, so first find the plug and clear it. The motor has an automatic reset, should restart after about 30 minutes, if it continues to shut off, there is still a plug.
Dec 12, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
678 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
