Question about Samsung Digimax 420 Digital Camera
Samsung 420 digital zoom error
Dear sirs ,
please note that my cam says zoom error that's why i can not use it for the moment .
can you please help me to solve this problem ?
thanks'n regards
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
Zoom error - samsung digital camera 4.0 mega pixels
Most likely the lens has been knocked out of aligment. If you look head on at the lens. The gap should be the same all the way around. You can try and "click" it back in to place yourself. Otherwise the camera is in need of repair, which based on most peoples level of experience should be left to a professional.
Thanks,
Lee
Jul 11, 2009 | Samsung Digimax 420 Digital Camera
I need program to instal my ClickSmart 420(logitech )
sir,you should install the user cd along with the cam,when you buy it.Or try to dawnload in logitech website.
Jan 20, 2009 | Logitech ClickSmart 420 Digital Camera
Zoom error
Turn Camera off remove batteries for a few moments. Re insert batteries. Turn on will reset itself. Ensure you use correct focus settings as per instructions. If you dont use correct settings this problem will reoccur.
Oct 27, 2008 | Fuji FinePix S1000FD Digital Camera
Samsung Digimax 420 digital camera
You can download the manual at http://www.retrevo.com
Hope this helps, Scott
Oct 23, 2008 | Samsung Digimax 420 Digital Camera
Dear sir whilst on holiday recently in brittany i bought a digital cam corder code vp-d3810 pal and when openig the box there are no instuctions in english can you please help m pritchard 212 park lane ...
Hi - You can download the manual by clicking the link underlined in blue below:
vp-d3810
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 08, 2008 | Samsung Cameras
When using the zoom button the cam stops working
This suggests the zoom motor has failed. As you only purchased it 2 weeks ago - it should be replaced under warranty
Aug 21, 2007 | Panasonic Lumix DMC-FX50 Digital Camera
Samsung Digimax 530 - Zoom Error
Check Customer support at Samsung. Unless you are a wathcmaker you and your screw driver will nothing to help.
Jul 30, 2007 | Samsung Digimax 420 Digital Camera
Samsung digimax 420 zoom error
The Zoom error could be motor failure or a connector come loose. you could try the Samsung Technical Help Team Byt I suspect it is time for repair or replacement[ depending on age of the device]
May 31, 2007 | Samsung Digimax 420 Digital Camera
Zoom lens jammed
this is a protection mechanism against further damage when the zoom/lens mechanism is obstructed. It's a very delicate mechanism, and it's not easy or cheap to fix. The gears probably got misaligned or broken when you dropped the camera. You should get a repair estimate, and only if you decide you'd rather trash it try opening it up again. Good luck
Jun 22, 2006 | Samsung Digimax 420 Digital Camera
Samsung Digimax 420 Digital Camera Logo
43 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
