Question about Carrier 52PQ307 Wall/Window Air Conditioner
My window ac is showing FL mode on display. what to do?
    Problem Solver:
  • 6 Answers
While AC is ON, press the MODE and Arrow Down button simultaneously for 5 to 10 sec until "FL" message disappear and room temp is indicated.
Posted on Jul 10, 2011
What does it mean FL on a Peak jumpstarter 900
read this
When the Jump-Starter is fully charged, the display will read FL. Disconnect the AC extension cord from the 110/120-volt AC outlet, and then disconnect it from the Jump-Starter AC charging
Amazon com Questions And Answers What does blinking FL means while...
Your manual is here
http://peakauto.com/wp-content/uploads/2017/01/Autotek-JS-PKC0AZ-Manual-031014.pdf
Mar 23, 2017 | Washing Machines
What does the flashing FL mean?
When the Jump-Starter is fully charged, the display will read FL. Disconnect the AC extension cord from the 110/120-volt AC outlet, and then disconnect it from the Jump-Starter AC charging plug. http://www.carid.com/images/peak/info/pdfs/pkc0j6-manual.pdf
Mar 29, 2015 | 600 AMP Jump Starter
Ac unit keeps reading fl or full. every 2-3 hours. auto clean button drains out about 1/4 a gallon of water and then stops draining. turn back on ac & repeat process every 2-3 hours. I have tried...
After reading over the Owner's Manual for your unit, I wonder if you are operating it in the Cool & Dry Mode. If that's the case, the dehumidifier is in operation, which would account for having to drain the unit every 2 to 3 hours. Ideally, the Cool and Dry Mode should only be operated for about an hour, when the unit is first started . Removing the humidity will allow the AC function to cool more effectively. But, it is not necessary for it to remain in Cool & Dry mode all the time. Because the AC itself unit will remove some humidity too.
Hope this helped you to troubleshoot and solve the issue of having to drain the unit every 2 to 3 hours
Jun 27, 2011 | LG LP1200DXR Portable Air Conditioner
Error code FL flashes and my calypso washer keeps beeping. Won't start just shows the code.
FL error - Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
You coudl se this manual: Service_Manual_PDF
Hope this helps.
May 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washing machine will not start... about 10 years old.. used to reset when i blew into the water level sensor - would show FL, then somehow rest itself.. not now it shows FL, can only get rid of the...
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%!#
Aug 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How can I turn down the power on the FL50 to get more flashes. Can you turn down the power on the camera E510 with hte FL50 attatched?
the user manual is here http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/accessories/man_fl50_e.pdf
Have a look at page 46 TTL Auto mode - you can adjust the variable between power setting - + or - 3 stops Page 48 gives full details on adjusting this setting
Light intensity adjustment
  • The flash light intensity can be adjusted between +3 and –3.
  • The light intensity adjustment must be set to ON in the custom setup operation (page 61). • The indicator appears in the control panel.
  1. Turn dial B to select a light intensity adjustment value in the following steps. (This selection is also possible with dial A.)
  • 0 → +0.3 → +0.7→ +1.0 ... +3.0
  • 0 → –0.3 → –0.7→ –1.0 ... –3.0
  1. The display shows the light intensity adjustment value except when the value is 0, in which case the display does not show the light control range.
  2. If the camera’s flash adjustment mode is selected, the actual flash light intensity will be the total of the light intensity adjustment value set on the FL-50 and that set on the camera. The light intensity adjustment value displayed is that of the FL-50 only.
Apr 11, 2010 | Olympus FL-50 TTL Flash
Every wash cycle FL shows on the screen, I have to extend the spin cycle to get all of the water out.
FL
Flood condition
Check the over fill switch hose for weakness or, damage if the FL code continues. if the hose is ok, replace the Over fill switch..
Jul 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL Code
FL Flood condition "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
Apr 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My ac is carrier company window a/c its indicating {fl}
From the manual.
Message on the display(electronic models) E4 1. Failure in the inside temperature sensor E5 2. Failure in the outside temperature sensor FL 3. Dirty filter
To fix vaccume  (or wash your filter) then  hold down "Select"(or "Mode") and "-" (or "^") for 3 secconds.
Jan 30, 2009 | Carrier 52PQ307 Wall/Window Air...
Carrier 52PQ307 Wall/Window Air Conditioner Logo
331 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
