Question about Xerox WorkCenter PE120i All-In-One Laser Printer
Soft copy of the printer
I want immediately a soft copy of the printer.. where to find it for the xerox Workcentre PE120i
    President:
  • 2,072 Answers
The guides can be located at Xerox.com under documentation. They can be downloaded easily
Posted on Jun 05, 2008
Where can I purchase DRUM cartridges for my Xerox Workcentre 24 as I need Magenta and Cyan immediately?
go to www.partsdrop.com or aaatoner.com
or if you want immediate supply go to your nearest xerox store and purchase it if you are in new jersey partsdrop is the wholesale dealer and they will give you drums and toners in wholesale price
May 08, 2014 | Xerox WorkCentre M-24 Color Copier
Need drivers for Windows 7 for my xerox workcentre pe120i
A Windows 7 driver is not available, but you may find that the Vista driver works OK. You can get it here:
http://www.support.xerox.com/support/workcentre-pe120-pe120i/downloads/enus.html?operatingSystem=winvista&fileLanguage=en
Feb 15, 2011 | Xerox WorkCenter PE120i All-In-One Laser...
My Xerox Workcentre PE120i screen says [no paper] "Add paper". but the tray is full of paper. What do you suggest I do?
This is a fairly common problem with most printers. It is generally caused by something confusing the sensor that detects the paper.
1) Remove all the paper from the printer.
2) Switch off the printer and unplug from the mains for 30-45 seconds
3) Switch printer on
4) Put in paper
5) Try and print!
Most of the time this will cause the printer to "reset" itself and should print fine.
Regards,
sjstore2
Dec 20, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
Unlock scanner
under the scanner where you retrieve you printed papers on the left side twords the front there is a slide lever (which is the lock for the scanner).
Apr 29, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
My Xerox Workcentre 385
Your probably got the copy key (readout) set at 10 copies. Try to go to the Xerox site and query for the instruction manual, this works most of the time. This will tell you how to negate the multiple copies
Jun 17, 2009 | Xerox WorkCentre 385 Laser Printer
Xerox WorkCentre PE120i - Paper Jam 1
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox WorkCentre Pro 215 E2 Error Code
Nov 19, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
I have a Phaser 8400 printer that needs to be repaired. Where are your authorized service stations in my area (Miami, FL 33142)?
Here you go
clear.gif UNITED DATA TECHNOLOGIES INC
8825 NW 21ST TERRACE
DORAL, FL 33172
Phone: 305-882-0435
Fax: 305-882-0436
Products Serviced: Phaser 8200, Phaser 860
clear.gif MONARCH ELECTRONICS INC
SUITE 319
1440 79TH STREET CAUSEWAY
NORTH BAY VILLAGE, FL 33141
Phone: 305-866-1885
Fax: 305-865-8087
Products Serviced: Phaser 6120, Phaser 8400, Phaser 8500, Phaser 8550, Phaser 8560, WorkCentre C2424
depot_logo_small.gif IT SOLUTIONS
7210 NW 58TH ST
MIAMI, FL 33166
Phone: 305-513-0059
Fax: 305-513-0062
Products Serviced: DocuPrint 4508, DocuPrint N2025, DocuPrint N2825, FaxCentre F110, Phaser 3150, Phaser 3400, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 740, Phaser 7400, Phaser 750, Phaser 780, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8550, WorkCentre C2424, WorkCentre PRO 423, WorkCentre PRO 423/428, WorkCentre PRO 428
clear.gif LASER PRINTER SOLUTION / FIX A FAX CORP
7240 NW 31 STREET
MIAMI, FL 33122
Phone: 305-471-0093
Fax: 305-471-0113
Products Serviced: Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 840, Phaser 8400, Phaser 8500, Phaser 8550, WorkCentre PE120, WorkCentre PE120I
clear.gif P M E INC
SUITE 130
10800 NW 21ST STREET
MIAMI, FL 33172
Phone: 305-994-9222
Fax: 305-994-9922
Products Serviced: CopyCentre C20, DocuColor 2006, DocuPrint 4508, DocuPrint 4512/4512N, DocuPrint N17, DocuPrint N2025, DocuPrint N2125, DocuPrint N24, DocuPrint N24/N32, DocuPrint N2825, DocuPrint N32, DocuPrint N3225, DocuPrint N40, DocuPrint N4025, DocuPrint N4525, DocuPrint P1202, DocuPrint P1210, FaxCentre F110, FaxCentre F116, N2025/N2825, N2125, N3225/N4025, N4525, N4525, Phaser 1235, Phaser 2135, Phaser 3150, Phaser 3200MFP, Phaser 3400, Phaser 3450, Phaser 3500, Phaser 4400, Phaser 4500, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6100, Phaser 6120, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 7300, Phaser 740, Phaser 7400, Phaser 750, Phaser 7700, Phaser 7750, Phaser 7760, Phaser 780, Phaser 790, Phaser 8200, Phaser 840, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8510/8560MFP, Phaser 8550, Phaser 8560, Phaser 8560MFP, Phaser 860, WorkCentre C2424, WorkCentre M20, WorkCentre M20I, WorkCentre PE120, WorkCentre PE120I, WorkCentre PE16, WorkCentre PE220
clear.gif ADVANCED BUSINESS COMPUTERS
1523 NW 89TH COURT
MIAMI, FL 33172
Phone: 305-477-2320
Fax: 305-477-3735
Products Serviced: Phaser 4400
Oct 01, 2008 | Xerox Office Equipment & Supplies
Workcentre pe 120i memory full
in spec. say's so:
your workcentre Pe120 have only 32 Mb memory.
fax function is equipped with a 4 Mb standard memory.
In spec. shows a 4mb memory is just enough for 320 pages of fax!!!
i think your problem is given from the 32 mb of memory of workcentre pe120, not from fax memory, because the faxes received or delayed is compressed with a very strong altgorithm, and these files is very small.
http://www.office.xerox.com/multifunction-printer/multifunction-under-30ppm/workcentre-pe120-pe120i/spec-enus.html#Memory
a link bellow ; i think is useful:
http://www.xeroxdirect.com/direct/public/products/accessorizer/dsp_accessory.cfm
for a 32 MB memory module (product code is: 097n01434)
Sep 23, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox WorkCenter PE120i All-In-One Laser Printer Logo
74 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
