Question about Hotpoint Dryers
Dryer is seriously overheating on all settings.
  • Hotpoint Master
  • 7,482 Answers
BE SURE TO UNPLUG YOU MACHINE FROM THE WALL BEFORE YOU START ANY WORK.
Your problem could be a Thermostats/Thermistors malfunction.
But this overheat condition also could be caused by a buildup of lint in the duct work, or a faulty blower motor/fan blade.
This will cause an overheat condition that you describe.
You will have to locate the air tube that is going to the dryer drum. Some general area the heater is located.
Is also where you will find most of them.
They normally are round/oval shaped and have two wires connected to them. Take off the wires and with an Ohm meter set to "continuity" check your thermostat/thermistor.
If you have continuity across the terminal it is not faulty.
Be sure to check all of the thermostats/Thermistors.
If this is not your problem then it will be the Control board if you have one on your machine.
Look for the fan blade to be in the air tube going to the dryer drum.
This is a FREE answer, Please Rate Me
Posted on Oct 16, 2010
My knock sensor comes on and thr car acts like it is overheating. Smells like antifreeze.
It is overheating. Find the coolant leak and repair it before serious damage happens. The knock sensor sets a codes because of the pinging of overheating.
Dec 07, 2014 | Cars & Trucks
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
I have a frigidare dryer 5-6 years old. Recently, started smelling like something electrical is burning. If I hold down the start button the motor will turn the drum slowly and the burning smell returns....
Check for vent blockages! Overheating may be a serious issue and fire hazzard. A slow moving drum could mean a bad traction belt, jammed mechanical part or the motor is not spinning at a proper RPM which may indicate motor damage also. The electrical burning is a serious issue also and a fire hazzard. Dryers need periodical cleaning to remove excess lint, dust and debris. Lack of cleaning causes the dryer to work harder and run hotter. Excessive heat shortens the life of many parts such as belts, bearings, electronics, wiring, etc...
Sep 21, 2012 | Dryers
Dryer drum loose not lining up properly making a huge thumping sound
Identification of Dryer Problems
Signs that an electric dryer may need some repairs include the dryer not heating, clothing not drying fast enough, overheating of the dryer, the door not locking shut and the dryer not starting at all. Any of these are signs of an underlying problem that can usually be solved without the help of a repairman.
Effects of Dryer Issues
If an electric dryer doesn't heat properly, it prevents the clothing from becoming dry in most cases. Restricted venting can cause clothing not to dry fast enough, as the dryer will cycle the heating. Overheating dryers can ruin clothing or cause burns. If the door on a dryer wont close, it is impossible to get any laundry dried. A dryer not running at all can be very frustrating and lead to owners needing to use a laundromat.
Considerations for Solving Common Problems.If the dryer wont heat up, owners should check the circuit breaker to see if it's down. The voltmeter at the wall plug should read 240 volts. Checking the power cord can show owners if the wires are burned where they meet the dryer.Clothing not drying fast enough and overheating are signs of restricted venting. Removing the vent hose from the dryer can help owners decide if this is the cause of clothing not drying. If the hose is removed and the dryer runs normally, the vent should be cleaned.White plastic or thin foil ducts can also lead to overheating. Only metal ducts should be used with dryers. Kinks in the vent hose can also lead to heating issues. Overheating can also be caused by a shorted heater coil, a bad operating thermostat or worn drum seals.If the door on an electric dryer will not close, it is usually a problem with the door catch. This can be solved easily by purchasing a replacement door catch for the dryer.
When a dryer wont run, it could be a number of issues. The circuit breaker may be down or the wires at the plug may be burned. It may be an issue with the door switch. The door switch should click when closed. The thermal fuse should be checked for any issues.
Preventing Dryer Problems
The electric heating element, thermostats, fuses and thermal cut-off should be checked regularly for continuity. Dryer vents should not exceed 18 feet without a helper blower in the duct. Vents that are run vertically need to be cleaned out once a year. A meter can be purchased and used to diagnose problems with your electric dryer.
Warnings and Tips.Inexperienced people should never try to fix electrical problems at home. A professional should always be used if dryer owners suspect a more serious problem. Dryer owners can purchase kits to make cleaning dryer vents easier.
Mar 11, 2011 | Whirlpool Dryers
My clothes smell burnt once they are done drying.
That means your dryer is overheating for two reasons:
1. The exhaust pipe is blocked. Or
2. The thermostat is broken.
This is a serious issue, a fire hazard. Stop using the machine and call for service.
If you can't afford service, check the exhaust line, there should be no clogs. Read the user manual, lint accumulation can cause fire. Your dryer should receive maintenance every 6 months.
I really really recommend you to get the machine services so you don't burn down your home.
Good luck.
Nov 24, 2010 | Hotpoint Dryers
Dryer won't turn on
beb2cb6.jpgCheck the duct fuse. Look for reasons why the dryer overheated829e4a4.jpge9ac79a.jpg03eafb2.jpg
May 29, 2010 | Whirlpool LER5636P Electric Dryer
Tumble dryer overheating!
It could be a faulty thermostat, or the high/low heat switch is faulty, it will be one or the other.
Hope this helps.
Jan 17, 2010 | Dryers
Dryer is making my clothes smell like smoke.
Clean out the dryer vent exhaust system. Check the gas burner for a clean blue flame with white tips. Air shutter on the gas burner may need adjusting.
Clean out any lint in the dryer cabinet.
Aug 30, 2009 | Whirlpool GGW9250PL Gas Dryer
Maytag dryer not starting
You must replace the hi limit thermostat and the thermal fuse.
They come as a set and must both be replaced.
They are located on the heating element.
Feb 21, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore electric dryer is overheating
Sounds like you need to replace the temp sensor.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
190 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
