Question about LG Panorama 20.5 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel
Hi The LG ref with the bottom freezer keeps shutting down. We must open and close the doors until it finally comes back on. Confused Alan
  • alan1888 Oct 23, 2010
    The light goes off inside but it also shuts down on all the lights outside on digital monitor. It also makes a very loud bang when it comes back on.
  • 2,299 Answers
By shutting down do you mean that the light is not coming on?
Posted on Oct 16, 2010
Tfx25ppbb. Water leaks into bottom of freezer when refilling ice tray in automatic ice maker. Ice still gets made but water leaks to the bottom of freezer. When enough freezes, it leaks out the door
It's probably not the ice-maker. It has a plugged drain. This is located in the back wall of the freezer near the bottom. remove the evaporator cover...(the back wall of the freezer). Below the coils is a trough with a hole in it where the defrost water drains. This is probably frozen over.
Pour some hot water in to trough until you see drain hole. Keep pouring until water runs thru drain. May have to shut down ref to get it to defrost.
Oct 20, 2014 | Refrigerators
Why does my frige motor turn on when I close the door and off when I open door?
It's designed that way for energy saving purposes. The motor shuts down when the door is open so that it's not producing more cold air to just fly out the door. Then when the door shuts, the cooling mechanism kicks back on again for business as usual.
Oct 20, 2014 | LG Refrigerators
I have a french door stainless LG refridgerator with the freezer on the bottom. I have ice building up in the bottom of the freezer. When I pull out the drawer there is a layer of ice on the bottom. ...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 19, 2011 | LG LFC23760ST Side by Side Bottom Freezer...
Water in the bottom of the freezer compartment, collects and freezes ,fills the bottom with 1/2 of ice. continues and runs out on the floor. LG LFX25975 Where is the water coming from? Doors and Drawer...
Leo Ponder
imufo2
Sep 03, 2011 | LG LFX25975SW (247 cu ft) Bottom Freezer...
Doors won't stay closed!
Frost in the rear of freezer possibly caused by door staying open.  Door staying open possibly caused by frost buildup on ref door track.  Start by making sure the teeth on the freezer track are clear of ice and frost.  This should allow you to shut the freezer door.  Next check the freezer seal.  If it is not completely sealed it it will build up frost. It is also possible that the frost in the rear of the freezer is from a failure in the defrost cycle as the evap coils are at the back of the freezer. If this is the case your refrigerator is probably getting warmer.
Oct 25, 2009 | LG (LRBC22522ST) Stainless Steel
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
Bottom freezer door opens when top door is open and then closed
the door pops open because freezer and frig. are connected together via duct. air pressure builds when you swing ref door closed. apply a small amount of vasoline to the surface of the hinge side of both gaskets. this will aid in door closure. also the unit may be not level
Jul 02, 2009 | Refrigerators
I have a side by side Viking refrigerator and after leaving the door open a little too long the lights went out in both the refrigerator and freezer. I figured that they would go back on automaticlly after...
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Mar 06, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
Jun 17, 2008 | LG LRSC-26922 Side by Side Refrigerator
LG Panorama 20.5 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Logo
54 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
