Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Freezer is not freezing anymore everything is defrosted. checked coils and they are ice free.
  • KitchenAid Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 16, 2010
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
Roper refrigerator is freezing everything even when the dial is turned off. Help, a root beer just exploded!!
First check for ice build up in the freezer, which would indicate a defrost circuit failure. Look for ice build up on the evaporator coil.
You might be best served by manually defrosting your refrigerator and seeing if the indications change.
Feb 01, 2012 | Refrigerators
We noticed that the freezer was not freezing well anymore, and the refrigerator was not getting cold anymore. I defrosted it, because the freezer was frosting up, which was weird because it is supposed to...
Hello there,
When your refrigerator starts building up ice at the back of the refrigerator and is not getting cold, the problem actually is caused by defrost settings of the refrigerator.
The defrost settings is composed of the defrost thermostat, defrost heater and the defrost timer. If any of the three should go bad, then the refrigerator would begin to build up ice and not cool.
You will have to test the defrost thermostat, heater and timer. Mostly the problem used to be the defrost thermostat.Once you check the three and see that they are okay, then you need to refill the gas cylinder with refrigerant.
Clean the condenser coil, refill refrigerant and test the thermostat, heater and timer.
That would get your refrigerator up and running.
All the best.
Elect_Comp
Oct 29, 2011 | Haier HTQ21JABWW Top Freezer Refrigerator
THE FREEZER STOP FREEZING AT THE TOP BUT THE BOTTOM
check the evaporator coil in the rear area of the freezer behind a panel for being iced over,if so defrost it with a hand held hair dryer,then check the defrost heater element for continuity under the coil,if this is o.k. then suspect a defective defrost control
Jul 10, 2010 | Frigidaire FRS26H7 26 Cu. Ft. Side By Side...
Refrigerator not cooling-Freezer Coils Freeze Up & Don't Defrost
check the fan assembly theres not enough air flow going over the coils
Feb 11, 2010 | Maytag MBB2254G Bottom Freezer...
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Ice under the cover
You can use a hairdryer to speed it up but you need to fix the defrost sytem.
How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 20, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Coils inside freezer keep icing up.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model of fridge)
Aug 08, 2009 | Refrigerators
I have a whirpool deep freezer that is not freezing. Can someone please help me with this.
If it is a frost free How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
Jul 13, 2009 | Freezers
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
