Question about Maytag Centennial MTW5800TW Top Load Washer
When turned to on the tub will not fill with water. However if you turn the knob to rinse it will fill. The machine is only 10 months old.
  • Colleen Smith Oct 17, 2010
    The question was...When turned to on the tub will not fill with water. However if you turn the knob to rinse it will fill. I have no problems with draining or spinning!
    Genius:
  • 1,417 Answers
Here are two ways solution to solve the washer problem below
PLEASE NOTE THIS
You will have to take note/ consider the Guarantee or WARRANT that cover the washer from the store or from the manufacturer from the day or date of purchase written on the receipt before you can apply the second solution below as do is your self offer.
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Here bare likely problem of the washer and their solutions below,
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car , lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • hope this help ?
    Thank you and thanks for visiting fixya.
    Posted on Oct 16, 2010
    How do you descale
    usually with a white vinegar cycle
    Mar 30, 2015 | Saeco Magic Comfort Plus Espresso Machine
    Our machine works fine, but the water just trckles in when it adds water for the rinse cycles. It can take 20 minutes to fill the tub.
    Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. Replace the water valve with this part.
    Jan 03, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washes until before rinsing and stops.
    I think the problem was a bad waterfill value. removethe water from the base
    RINSE/DRY = Water filling fault (over or under filling)
    regards
    balisonu79
    Jan 04, 2010 | Bosch Washing Machines
    Low Water Level in Roper washing machine
    You need to check the pressure switch which is also called the water level switch. There is a small tube attached to it and it may have a blockage or a hole in it. You can find this behind the control panel to the left of the timer.
    Nov 14, 2009 | Washing Machines
    Washer tub won't stop filling with cold unless tap is off
    Sounds like jammed open solonoid valve on hot or cold......water?,,quite simple to fix parts about *£8.00
    Nov 02, 2009 | Washing Machines
    THE TUB OF THE WASHER GETS REALLY LOW WHEN IS FILLED WITH WATER. NOW, ALSO THE WATER DOSENT COME IN WHEN I TURN IT ON
    All top suspend tub washers drop down when they fill with water. And they rise again when they have pumped the water out. This is normal.
    What is not normal is water not coming in.'
    check following:
    Water is turned on
    Remove inlet hose and run water to see if it is blocked.
    Clean the inlet filters.
    If you hear a buzz but no water goes in the inlet valve needs replacing.
    If yu use only cold water try swapping the cold hose onto the Hot inlet. Then select Warm Wash.
    Then only turn on the Cold Tap.
    This will allow you to fill the machine and do a wash.
    Watch out though when it comes to the Rinse position......some machines only do a cold rinse, and because you have swapped the hose over to hot it will not fill to rinse the clothes. Until you can get a Tech to do the repair you can just use either a bucket to add cold water for the rinse or use the garden hose to fill the tub with cold water for the rinse.
    Have yu got all that?
    Oct 25, 2009 | Speed Queen AWS75NW Top Load Washer
    Kenmore 80 Series Overflow
    We've now had this happen three times and the exact same thing caused it all three times.
    If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
    As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
    Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
    I want descalcificacian saeco easy sup 021ye what butons y press?
    Warning! Never use vinegar as a descaling agent. You can use any commercially available non-toxic, non-harmful descaling product for coffee machines.
    Descaling is necessary every 2 months; should water be very hard, descale the machine more frequently. The machine must be on; it automatically controls the distribution of the descaling solution.
    1. Switch off the machine.
    2. Fill the water tank with the descaling solution.
    3. Place a large receptacle beneath the steam tube.
    4. Switch on the machine.
    5. Open the knob.
      The descaling process starts.
    6. Dispense the descaling solution into the receptacle.
    7. After about 30 seconds close the knob.
    8. Switch off the machine and remove the receptacle.
    9. After 10 minutes, follow instructions 1 to 8 to the water tank is empty.
    10. Rinse out the tank and fill it with fresh drinking water.
    11. Place a large receptacle beneath the steam tube.
    12. Switch on the machine.
    13. Open the knob to rinse.
    14. If the receptacle fi lls, empty it.
    15. When no water is left, turn the knob to close the valve.
      Remove the container.
    After descaling the machine, reload the machine circuit. Install the cartridge filter again in the water tank.
    Jul 23, 2008 | Saeco Easy Espresso Machine
    Hot water continues to run after rinse, filling tub overflowing
    sounds like you are right the water inlet solenoid on the hot side is sticking remove the hoses and clean th escreen out and the valve try agin with a fill on hot to see if it stops on a small load if not replace the water inlet valve
    Mar 15, 2008 | GE WVSR1060A Top Load Washer
    Won,t drain on rinse cycle
    There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
    Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
    Maytag Centennial MTW5800TW Top Load Washer Logo
    42 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
