Question about Toshiba Satellite P205-S6287 Notebook PC
Problem with the touchpad
Hey!
Everything works fine on my laptop except for the touchpad. The touchpad works fine but when I plug in the power cord tocharge the computer, the mouse starts going haywire every time I try tomove it around. Does any of you know what the cause could be?
When you plug the ac plug in do not have the unit on. then turn unit on to see if all is well with the touchpad area.
Posted on Jun 16, 2008
Hi, I have a Asus N55S laptop and the touchpad
warranty repair. send it in for repairs.
Aug 12, 2013 | ASUS Computers & Internet
Touchpad does not work while laptop is charging
Voltage can mess with digitizer of any touch screen. Most like the aftermarket power cord is drawing slightly too much power or slightly too less. My guess is slightly too much and when you are setting it on your lap, you are grounding that extra current. Find an original power cord and see if problem persists.
Oct 24, 2017 | Computers & Internet
Built in mouse has not worked properly from day 1. Now my external mouse won't work either. I tried a different external moue, but it doesn't work either.
Unplug everything except the power cord, including the following:
Speakers
Printers
Scanners
USB devices
Personal Digital Assistants (PDAs)
USB flash drive or other external storage devices
External Monitor
External Keyboard
External Mouse
If your computer is attached to a docking station, undock it.
Make sure the touchpad or your finger has no dirt, grease, liquids or food on it (the touchpad has to make a good contact with your finger to work correctly).
Turn the computer back on and retest the touchpad.
When the touchpad still does not work correctly proceed to step 5.
When the touchpad does work correctly, attach one external device at a time and test the touchpad to see which one may have caused the issue.
Make sure the latest driver for the touchpad is installed (you may need to use a external USB or Bluetooth mouse), for more information refer to:
"How to Use the Drivers and Downloads Website"
May 26, 2011 | Dell Inspiron 1525 Laptop
Cursor wont move when power cords in
reinstall the touchpad drivers while ac power is on
Nov 12, 2008 | HP Pavilion dv6000z Notebook
Laptop will not power up.
You have a bad battery. I had same problem before and i just replace my battery and it works fine again..
Oct 09, 2008 | Gateway MX7118 Notebook
Touchpad Not Working
If you has been installed the right drivers, it is hardware problem.
Try to use the factory touchpad program for your sony touchpad and see what happen (not only the driver, also the program touchpad software)
Oct 06, 2008 | Computers & Internet
Go to Device Manager, right click on yellow !, use windows update to update driver
If that doesn't work, do a complete wipe out and do a clean install of new Operating System.
Jun 23, 2008 | Gateway MT3705 Notebook
Cursor stops working when power cord is plugged in...
It sounds as if the power coming through your ac adapter may be causing interference with the touchpad, meaning perhaps an electrical signal is crossing into your mouse or disrupting its signals.
You could try to download the latest drivers for your touchpad and see if that fixes the issue.
You should also (if you haven't already) try a different mouse to see if the issue is related to the mouse sub system, or the touchpad itself.
If possible, try a different AC Adapter to see if that may be the issue.
Mar 27, 2008 | Dell Inspiron™ E1505 PC Notebook
Keyboard/touchpad freezes when the battery is plugged!!
I SOLVE THIS ISSUE 100% WORKING
THE MAIN PROBLEM IS ON THE CONTACT BETWEEN THE BATTERY WIRES AND LAPTOP
IF YOU MOVE THE BATTERY IT WILL WORK SO SURE THE PROBLEM WITH THE LINK BETWEEN THE BATTERY AND THE LAPTOP
SOLUTION : TO MOVE THE IRON OUT OF THE LAPTOP TO THE RIGHT TILT THEM TO RIGHT SIDE A LITTLE BECAUSE THE BATTERY WIRES IS TO THE RIGHT SIDE (WATCH THEM) NOT IN THE MIDDLE AND AFTER THAT PUT A STICK ON THE BATTERY TIGHTED IN ITS PLACE SO IT WILL NOT MOVE ITS NOT FREEZING NOW THANKS
Dec 21, 2007 | Acer Aspire 5100 Notebook
Toshiba Satellite P205-S6287 Notebook PC Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
