Question about Baby Lock Sewing Machines
After running my Babylock Serge BL4-728 for a few minutes it starts to bog don and run really slow, almost stopping. What could be the problem?
  • Mister Fixit
    Mister Fixit Mar 15, 2015
    The culprit is dry oil packings on either end of the motor. What happens is as the motor starts to run the shaft and bearings heat up causing the armature to almost seize up hence the slow down. To correct the problem remove the right side cover and the rear cover that shields the motor. Once the motor is exposed you will be able to visually see the oil packings through the air vent holes on either side of the motor. Apply numerous drops of oil onto the packings allowing them to soak in after each drop. A dozen drops on each side should due the trick. Happy Serging!
  • 21 Answers
Posted on Mar 15, 2015
How did you fix that problem. I run into same problem
Posted on Jul 16, 2013
  • 43 Answers
SOURCE: baby lock-sewing machine
The BL4-728 was manufactured between 1989-1991.
Posted on May 14, 2009
jmgldsmth
  • 1869 Answers
SOURCE: i have no manual and cant figure the threading
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300126694758
Posted on May 20, 2009
SOURCE: I need a manual for a babylock BL4-543DF
I require a manual for BL4-543DF can you help
Posted on Sep 18, 2009
  • 30 Answers
SOURCE: Babylock Serger loosing power
Your problem is probably the stitch length adjustment cam (located on the left side of the machine) To fix this problem you will need to remove the small plastic cap (with red arrow) covering the screw securing the cam. It is usually also necessary to remove the connecting rod/sleeve that the cam rides in. Once both of these parts have been removed, you will need to carefully separate them and resurface the inside of the sleeve. This can be done with a very fine (500grit or higher) emery paper. Once the cam fits inside the sleeve without binding, reassemble using sewing machine oil or lithium grease and adjust feed dog timing.
Posted on May 17, 2011
SOURCE: The foot pedal that controls my Babylock Proline
try these two websites for the part
sewingpartsonline.com
sewvacdoctor.com
Posted on Aug 13, 2011
I need a manual for a Serge Mate 4350D
Babylock Model 4350 D Serge Mate Instruction Manual
www.sewingmachinemanual.net/...Manuals/.../Babylock_4350-D_instruc...
Babylock 4350 D Serge Mate Instruction Manual. Contains 20 pages of information on how to thread, maintain, and operate the machine. This manual is ...
Where Can I Get A Free Instruction Manual For Sergemate ...
arts-literature.blurtit.com/.../where-can-i-get-a-free-instruction-manual-fo...
Answer (1 of 1): Www.simplicitysewing.com and go to downloads... I was able to download same manual in a matter of minutes.... Good luck.
Nov 05, 2015 | Sewing Machines
After setting up the embroidery module and preparing the thread, plate, and needle and then choosing design and hoop it wont sew. Yes, it is on. Foot pedal connected. The reverse button will not sta
Can you describe your problem a bit better.
From what you describing it sounds like the machine does start to embroider, it starts slow then it stops.
It is normal when you first start to embroider that the machine runs very slowley, does just a few stitches and stops. This is normal and all Berninas do this. The machine stops after these first few embroidery stitches so you can cut off the extra piece of thread. Cut off the extra thread then push the reversing button again and the machine should start to embroider. It will stop again if a color change is needed. This information is provided in your owners manual.
Make sure you have lowered the feed dogs for embroidery and there is no need to have the foot control attached for embroidery though it won't affect anything if it is attached to the machine...
Sep 16, 2014 | Bernina Artista 180
Babylock 5360e
try new needles
make sure to use ever thread guide
also check the tension
if none of these suggestion help then it may be time to have the machine serviced
Jan 19, 2014 | Sewing Machines
Motor runs but will not serge
Sounds like a broken belt. Take it in for repair (don't do it yourself... it's easy to mess up the timing.) have it cleaned, oiled and adjusted while there.
Aug 04, 2012 | Baby Lock Eclipse Serger
I can serge just a few minutes then it slows to a crawl.
it could be the motor, or power cord or foot pedal
it needs to be serviced at a sewing machine repair shop
Feb 26, 2012 | Sewing Machines
My brother Se 400 which is only a few months old just started running really slow. When I disconnect the foot petal and do the manual botton "the arrow button" it still runs slow. I don't...
have you checked to make sure the power cord is pushed in correctly?
if the power cord isn't the problem then it may need to be checked by a service tech, because it's not suppose to be running slow just a few months after you bought it.
I would call the people you bought it from & tell them what it's doing & see if they'll give you another one, I've been sewing for 30+ years & I wouldn't keep the machine.
good luck
Sep 22, 2011 | Brother Sewing Machines
Jul 13, 2009 | Baby Lock Eclipse Serger
Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Jun 12, 2009 | Baby Lock Eclipse Serger
Sewing Machines Logo
376 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
