Question about Panasonic Microwave Ovens
Panisonic microwave model NN s952wf Problem; has power (lights. clock and touch pad function), microwave and turn table do not work?
  • Panasonic Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 16, 2010
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
Panaonic nn 1000 gs 597 no working microwave
follow this steps and fix it. God bless you
No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models
Jan 23, 2013 | Panasonic NN-H965 Microwave Oven
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Demo mode on
    The instructions to turn the demo mode OFF on the model you have listed, can be found on page 24 of the owner's manual. Press the CLOCK pad three times to clear. If you no longer have an owner's manual, you can download a FREE copy at managemylife.com. Here's a direct link:
    http://www.managemylife.com/mmh/owner_manuals/6952/PANASONIC-Countertop-Microwave-L0604142?brand_name_search=NN-C994S
    I hope this helps you.
    May 03, 2011 | Panasonic NN-C994S Convection/Microwave...
    Everythink works except the microwave will not start. Is there a fuze that can be replaced to fix this ? Model # NN-2551 I found the user manual on-line, but I can't find the product spec sheet breakdown...
    I'm not sure what you mean by "everything works". do you mean that all the lights and the timer work. Could it be in the timer or clock mode? Try pushing the timerand cancel buttons together.
    Try changing the time using the clock function.
    I believe your model has a child lockout. Please check your manual for instructions on unlocking this function.
    Is it hardwired or plugged in? If it is plugged in you can try a power reset, by unplugging it, waiting a few minutes and plugging it back in. It is completely unsafe to try to work on a hardwired Microwave.
    Please let us know if this solution is helpful to you. Thank you.
    Dec 20, 2010 | Panasonic NN-S255 Microwave Oven
    Panasonic NN-S740BA Microwave oven
    In all likelihood the mangnetron is failed or failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
    Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one
    Jan 27, 2010 | Panasonic NN-S740BA Microwave Oven
    The clock works & counts down but the microwave won't heat
    • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
    • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
    Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
    Aug 03, 2009 | Sharp R-1460 Microwave Oven
    PANASONIC NN-S952WF FAN AND CAROSEL STILL CONTINUES WHEN DOOR IS OPENED. NOT SURE IF THE MICROWAVE CONTINUING AS WELL WHEN DOOR IS OPEN.
    The door interlock system has beem compromised , meaning it shifted out of position or the interlock has broken. Dont continue using it like that it will eventually blow the fuse.
    May 13, 2009 | Panasonic NN-S952 Microwave Oven
    I have a panasonic range microwave oven model NN-H264/S254 clock cannot be set. (It use to work but no longer can be set)
    Sounds like you disabled the clock function. If you do not have the user manual, you can get a copy at this website and use the function keys to reactivate and set the clock...
    http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/NN-H264-_E
    I belive the information you seek is on page 12 of the manual.
    Hope that helps...
    Aug 13, 2008 | Panasonic Microwave Ovens
    Microwave Ovens Logo
    147 people viewed this question
    Top Panasonic Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Jerry Greenberg
    Jerry Greenberg
    Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
