Question about GE JE1860 Microwave Oven
GE Microwave Modes JES 1451 won't heat. Can't locate fuse.
SOURCE: Sharp Carousel Microwave ESP Sensor R-1451 1.50 w 850wats has load noise and will not heat, what could be wrong?
Microwave still heats but there is a hole in the fiber door on top surface of microwave.
Posted on Apr 06, 2008
SOURCE: No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Posted on Sep 21, 2008
  • 333 Answers
SOURCE: ge spacemaker microwave has no power how do i change the fuse?
First you have to unplug your device. Next you must remove the cover from the micowave. Follow the powe cord to the unit the fuse should be right at the beginning of the powe cord. I hope yhis will help you.
Posted on Nov 26, 2008
  • 140 Answers
SOURCE: GE less than 2 year old microwave runs, doesn't heat
The problem you are having is that the magnetron that actually does the heating has gone bad. The fact that everthing works fine rules out any type of bad fuse since there is only one 15amp ceramic fuse in most cases in the unit itself. The magnetron is located behind the control panel on top and has some cooling fins on it. Replacing it if you are a do-it-yourselfer is pretty easy provided you can find one at local electronic supplier or on the internet such as www.mwoparts.com if you would like to see what it looks like. It is held in place with typically 4 screws. It has two to three terminals depending on make and model and age. With everything unplugged it comes off easily enough with no desoldering or soldering to do. There is a High Voltage Capacitor and Diode that could be bad also, but without being able to check it in person it would be difficult for me to tell that they are. In my experience the magnetron is the first thing I replace and have never replaced a capacitor or high voltage diode in the past 20 years. Good luck and God bless.
Posted on Jan 23, 2009
domotek
  • 591 Answers
SOURCE: My GE JVM1540 microwave appears
you will have to replace the microwave, sounds like a burned out magnetron, replacing the magnetron is almost as expencive as a new oven...
Posted on May 05, 2011
Where do i locate the fuse
Although you have not mentioned the model/make, take a look at the video here for replacing a Thermal fuse. Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
on traditional fuse see
How to Fix Microwave Oven Simple Fuse Replacement
Mar 08, 2016 | GE Microwave Ovens
How do I change the light bulb in a JES 1451 ?
On this model, it's not meant to be a user serviceable part.
You would have to remove the outer cover, and then the light bulb is located on the air duct attached to the magnetron on the right side of the innards.
You can find helpful exploded views and order the bulb assembly from the Pros here.
Enter your full model number from the tag with suffix and no spaces.
See these help files on safety and disassembly first.
Nov 30, 2012 | Microwave Ovens
I have a GE JES 1456 WF001 sensor microwave, of coarse it stopped working but it gave me no warning what so ever.However its not doing anything, want light up, can't press any buttons, what's the...
It may be a blown fuse or thermostat / TCO / thermal cutout.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 18, 2011 | GE Microwave Ovens
Possible blown fuse
Your on the right track .This is the first thing I all ways ck, first. If you need help let me no . DFD
Apr 19, 2009 | Microwave Ovens
Follow-up (no power)
if you remove the case theres a 15 amp fuse in there , looks like the old automotive glass fuses but its not glass . it sometimes will blow for no reason , remove it and take it to any appliance parts place . .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 08, 2009 | GE JES1238 Microwave Oven
Jan 23, 2009 | Jenn-Air JMC7000 Microwave Oven
Ge spacemaker runs but wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Lights up, makes noise turns table doesn't heat at all?
WHAT POWER SETTING DO YOU HAVE IT SET AT, CHECK IT
Jan 12, 2009 | GE JES1039 Microwave Oven
Is the 1.1 cu ft 1100 Watt model: jes 1139bl sold by Home Depot the same as the 1.1 cu ft 1100 watt model sold by Lowes ? If so, what is the model number of the lowes unit ?
A quick check of the Lowe's Web site show the following GE 1.1 cubic foot microwave models:
JES1142SJ
JES1139WL
JES1139BL
JE1160WD
JE1160BD
If you still have any doubt, I'd call Lowes.
Aug 23, 2008 | GE Microwave Ovens
GE JE1860 Microwave Oven Logo
146 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
