Question about AO Smith 1 hp 3450/1725rpm 56J Frame 230 Volts 2 Speed Swimming Pool Pump Motor - Electric Motor
How to remove hayward pump - AO Smith 1 hp 3450/1725rpm 56J Frame 230 Volts 2 Speed Swimming Pool Pump Motor - Electric Motor
  • Mike Raino Oct 17, 2010
    Do you mean how to separate the motor from the wet end?
  • 8,404 Answers
Remove the motor back cover ... you will see there are flats on the armature. Move the Cap to the side ... apply the proper wrench (7/16 I think)... this will help you to remove the impeller. Now you can remove the motor from the adapter plate.
Posted on Oct 21, 2010
Removing the lid from a hayward power-flo matrix
Too Much Pressure????
Are you trying to remove lid when the pump is on? NO, NO, NO
If not, then good! If you have valves before and after the equipment, then close them. Then remove the small 1/4" drain plug to empty the pot. Then try removing the lock ring and open it up.
Jul 13, 2013 | Hayward 1hp Power Flo Matrix Above Ground...
Hayward pool pumps
The impeller on this Hayward pump unthreads counter clockwise.
Take a big flat head screw driver and put it on the center shaft on the back of the motor to hold the shaft solid while you unthread the impeller.
Rod
US Parts Center
May 08, 2013 | Pool & Spa
We need to change the sand in our filter ,it is a sw256t hayward ,but dont know how to remove other sand,does anyone know how?
Once you have the plumbing disconnected and valve removed,
Use a shop vac. Works well.
Once the sand is almost all removed, you can tip the tank over & rinse out with hose for the rest.
Jul 28, 2012 | Hayward Pro Series 18" Above Ground Pool...
Pump seal leaking
Pump seal replacement on Hayward pump is simple to do - takes about an hour which should include removing the motor from the pump body. Parts are less than $20.00. Get the seals at your professional Pool Supply store.
Aug 03, 2011 | Hayward SAND FILTER, PRO SERIES
How to remove hayward super pump difuser
They just press into place and to remove them you pull straight away from the rest of the motor/pump parts.
Oct 02, 2009 | Hayward 1HP Super Pump II Inground Pool...
Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
Jun 10, 2009 | Hayward 1.5 Hp Northstar High Performance...
How do you change a pump seal on a hayward 1hp pool pump
The seal is located behind the impeller. Once you remove the impeller it is fairly obvious how to replace it. Basically, unscrew everything, replace it and put it back together again. There is a decent diagram on page 11 of the Hayward owners manual found here if you need it. http://www.haywardnet.com/products/Manuals/pdfs/Manual113.pdf
May 13, 2009 | Hayward 3/4hp Super Pump Inground Pool...
AO Smith 1 hp 3450/1725rpm 56J Frame 230 Volts 2 Speed Swimming Pool Pump Motor -  Electric Motor Logo
118 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
