Question about Kenmore 24032\24036 Top Load Washer
This machine will not spin and I smell a burning smell of rubber. Did the belt break?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler. The "Stock Numbers" that your question was posted under do not use a belt.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
Hence the burning rubber smell.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Oct 16, 2010
4 Suggested Answers
  • 686 Answers
SOURCE: washing machine spins slowly and smells of burning rubber
Your washer has brake problems you need a qualified repair person
Posted on Apr 03, 2009
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Posted on Apr 21, 2009
mindreader
  • 578 Answers
SOURCE: The Maytag washer doesn't spin and had a burning
You should have a tensioner pully (a small wheel on a piece of spring steel) that hold the belt tight.
If that spring steel is broken or weak, then you will have to take the broken one to your local appliance repair parts shop and obtain a new one.
That should keep the belt tight and keep the drum spinning.... -Jim
Posted on Oct 23, 2009
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Heating extremely fast and smells like burning rubber
If it is a belt driven dryer the belt may be spinning on the motor shaft and it may be bad. Hence the burning rubber smell. Have it checked.
Dec 02, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Battery light on and a strong burnin rubber smell
SOUND LIKE ALTERNATOR SHAFT BEARING FAILING CAUSING ALTERNATOR PULLEY LOCK OR PUT DRAG ON DRIVE BELT CAUSING BURN RUBBER SMELL OR DRIVE BELT LOOSE CAUSES BELT SLIPPAGE MAKE BELT RUB AND BURN.WHEN YOU SMELL RUBBER BELT BURN SMELL WATCH OUT DRIVE IS GOING TO BREAK.
Aug 04, 2011 | 1983 Ford Fairmont
Smell rubber burning when on spin cycle
This sounds like the belt is slipping, which will burn the rubber and give you that smell. Replace the belt and be sure the tension pulley spins easy.
Jan 07, 2010 | Westinghouse Washing Machines
Washing machine spins slowly and smells of burning rubber
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
The washer driving belt breaks.
Sounds like a spin bearing might be bad:
Check this link:
http://www.fixya.com/support/t197849-burning_smell_screeching_sound_but
Apr 21, 2009 | Kenmore Washing Machines
Burning rubber smell
Even though manufacturers' love to advertise it, I personally would not load "too many items", as it may cause excessive normal ware and tear on your machine parts, motor, belt, etc.
Yes; the smell can be the belt and possibly your motor as well. The motor may be spinning, but the weight may be too much when the belt is engaging to rotate the drum. I would be careful not to burn the motor (About $120 - part only)
You should be able to access and inspect the drive-belt in the rear of the machine by removing an access panel (back of washer).
To replace the belt if fairly simple. Remove and re-install by wedging a long screw driver in between the belt and metal pulley (circular), while simultaneously rotating the pulley.
You may be required to make a belt repair if you start to have problems with your "washer not spinning" or "making a noise/not spinning"
Jan 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 24032\24036 Top Load Washer Logo
62 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
