Question about Graham Field Everest Jennings E3010100 Traveler SE Steel Wheelchair 18" Seat Fixed Full Arm Swingaway Footrest 1 Each Black 32" X 36" X 27" ()
Thumping of wheels - Graham Field Everest Jennings E3010100 Traveler SE Steel Wheelchair 18" Seat Fixed Full Arm Swingaway Footrest 1 Each Black 32" X 36" X 27" ()
    Novelist:
    Champion:
  • 232 Answers
Check to make sure the wheels do not have any pieces missing from them and that the rubber tire has not come off the rim. Check to make sure the bearings inside the casters are not rusted or damaged so that they will turn freely.
Hope this helps- good luck!
Posted on Oct 20, 2010
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
Have a thumping noise, thought it was cv joint. Removed axels, they are good. Noise is there only when car is moving. Frequency inceases with speed. Wheel bearing roll smoothly.
Rhythmic thumping noise when car's moving - Car Talk
community.cartalk.com/.../rhythmic-thumping-noise-when-cars-moving
Jun 4, 2013 - Hello, I have started hearing faint thumping noise in my Murano, coming from the front most likely.
Sep 24, 2015 | Cars & Trucks
Thumping noise driving
Not sure what the "mechanic" actually did but you may have lost a wheel balance weight.
Jul 19, 2017 | 1999 Volvo S80
Hello. I hear a very loud thumping noise from the back of my 2014 Toyota Corolla as I slow down. I have taken it twice to the service station at the dealer and they hear the noise but cannot identify where...
Here are the only reason that can cause a thumping noise
  1. Wheel and Tire Problems
    • Wheels can become bent from striking objects, and tires can develop bulges from broken belts or wear. Both problems may cause a thumping noise. Thumping sounds caused by wheel and tire problems will typically increase in frequency at higher speeds, though the sound may not be heard at lower speeds. These problems can often be spotted by visual inspection.
    Suspension Problems
    • Worn or broken struts or strut mounts can create a thumping noise, especially when the vehicle hits a bump in the roadway. To test struts, bounce the rear of the car by forcefully pushing down on it and letting go. After letting go, the car should settle back to its original position without bouncing or noise.
    Loose Trim
    • Loose trim pieces near or in the wheel well can flutter in the wind while a car is being driven. These trim pieces may create a thumping noise as they strike other objects. A car owner can check trim pieces for looseness to determine if that is the source of the noise.
Hope this helps
Feb 20, 2014 | Cars & Trucks
What is the cause of continual thumping (appears to be coming from back of car) and violently shaking?
Many times, rear tires that are out of round or severely cupped or feathered, or that are out of balance can create this type of issue. My first recommendation would be to have them and the wheels on the rear of the car inspected. There may not seem like there is much wrong visibly if you look at just the tread of the tires, but a good tire tech can spin them up and give you some solutions, and the inspection itself is inexpensive. Hope this helps.
Jun 19, 2012 | 1997 Nissan 200SX
Subaru 03 Forester - problem in front differential, 3 wheels turn
Thumping noises and vibrations can be something as simple as a tread separation(or a big bubble) on one of your tires.As for the one wheel turning---that's perfectly normal.If you grab the wheel that's turning (not really recommended) and stop it completely,the other wheel will spin.
Mar 01, 2010 | Subaru Impreza WRX STi Cars & Trucks
Steering wheel vibrates thumping noise
At what speed do you feel the shake and does it only happen when you apply the brakes?
Mar 02, 2009 | 1995 Nissan Maxima
Graham Field Everest  Jennings E3010100 Traveler SE Steel Wheelchair 18" Seat Fixed Full Arm Swingaway Footrest 1 Each Black 32" X 36" X 27" () Logo
52 people viewed this question
Top Graham Field Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Graham Field Health and Beauty Expert? Answer questions, earn points and help others
