Question about Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher
There is a light at the (lock symbol 3) position on the keypad. Any troubleshooting hints from the manual won't shut it off. Needless to say the dishwasher is completely inoperative. Any suggestions?
  • 5,081 Answers
You have the control panel locked. Hold down the heated dry button for 3 seconds.
Posted on Oct 16, 2010
The lock symbol is showing but the door can open and no functions on the oven will work apart from the clock
This is the keypad lock (symbol looks like a padlock?). Find the button that has a padlock symbol near it, hold down for 3 seconds, should unlock your keypad. This should be described in your user manual if not indicated on the touchpad.
Aug 28, 2015 | Ovens
I have a T1700 in my apartment and my air want shut off and i see a lock symbol on it how do i shut it off
Do you mean a Venstar T1700 thermostat? If that is the case, the Lock symbol merely indicates that the keypad is locked to keep people from reprogramming the thermostat. This prevents anyone from quickly changing the target temperature or the swing temperature (the temperature at which the unit turns on) for the HVAC system. To unlock the keypad, press and hold the Mode button. Then press both the Up and Down arrows. Release all three buttons when the lock symbol disappears.
If the AC has cooled your apartment to a temperature below the target temperature for the current time period, then the control board of the HVAC may be damaged. (It isn't getting the message and has failed in the on position.) Contact an HVAC repair professional.
If the thermostat is indicating that the room hasn't reached the target temperature, then you should replace your thermostat. The thermistor has failed. (Contact Venstar if the thermostat is less than one year old.)
I hope this helps.
Sep 27, 2014 | Heating & Cooling
Honeywell thermostat is locked in the off position
sounds like keypad is programmed in lock position read manual for set up to activate keypad again.
Nov 25, 2012 | Honeywell Programmable Thermostat Heater
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
My keypad won't light up when door is locked whe you push lock won't light up green
Aug 04, 2011 | Kwikset 909 909-L03 Lifetime Polished...
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Frigidaire FDB1100RHB dishwasher troubleshooting
YOU SHOULD SEE A SYMBOL OF A PADLOCK PLACED BETWEEN 2 BUTTONS ON THE CONSOLE. PRESS AND HOLD BOTH BUTTONS AT THE SAME TIME TILL THE LOCK LITE SHUTS OFF
LEVI
LEBARCHRIGEN APPLIANCE REPAIR
WWW.LARTODAY.COM
Dec 11, 2009 | Frigidaire Dishwashers
Lock 9 light is on
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, hold down <Fn> and press the desired key.
  • To enable the keypad, press <Num Lk>. The keyboar2.jpg light indicates that the keypad is active.
  • To disable the keypad, press <Num Lk> again.
Mar 20, 2009 | Dell Latitude D410 Notebook
Ican"t type numbers can you please help
From Dell user manual:
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, press <Fn> and the desired key after enabling the keypad.
Jan 13, 2009 | Dell Inspiron 6400 Notebook
2003 ford futura programming a new keypad
Adding and Removing remote Keypads to the Smartlock module
Up to four Keypads can be programmed and used with the Smartlock Remote
Central locking system.
If you have replaced the BEM, or new keypads are being added to the
system, you will need to train the keypad codes to the module.
# 1. The ignition switch should be in the Off position, with all the
doors shut and Unlocked.
# 2. Turn the ignition key to the ACCESSORY position and within 5
seconds, operates the rear demister switch exactly three times in quick
succession. (IE. Press the switch so the Demister light turns on, then
off, then back on again.)
# 3. After the 5 seconds is up, the door locks will change state, to
indicate that the BEM has entered keypad learn mode.
NOTE : All existing keypads at this point, have been erased from memory
# 4. Press either buttons on the keypad that is to be trained. The door
locks will change state twice, to indicate that the keypad has been
added to the BEM memory.
# 5. Follow step 4. for each keypad that is to be added to the BEM
memory. A maximum of 4 keypads can be added to the BEM memory.NOTE :
You must teach all remote keypads for the Smartlock module, before
proceeding.
# 6. When you have taught all the remote keypads, turn the ignition to
the Off position to leave the learn mode. The door locks will change
state to indicate a return to normal mode.
# 7. Check the function of both buttons on each keypad, to ensure that
the keypad has been trained.
Sep 15, 2008 | Ford Futura Cars & Trucks
Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher Logo
273 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
