Question about Hitachi Televison & Video
Says my hdmi ports are unsupported. they worked yesterday but now it wont work on the dvd player, xbox 360, or the ps3. got any idea of how to fix this or how i can reset the tv?
Hay there i have the same problem and found out my LCD does not support xbox360 via hdmi have to use a componets cable not the standard av cable its the ones that go in to the YB,YR,PR slots like an RCA but they are actualy HD quality cables that will give same affect as using the HDMI cable and its hlf the price to!!. With the use of the components cable you will be able to veiw xbox360 in full hd up to 1080i or 1080p hope this helps as there many unanswered questions here! Who the hell runs this site? They arent very helpfull ay!!!!!!!!!!!!!!! Regards Matt Rocket
Posted on Oct 29, 2010
No power when plugged in in any socket.
Solving HDMI Problems - HOW TO GUIDES
www.hdtvsupply.com > HOW TO GUIDES
Rating: 4.7 - ‎2,086 votes
The hdmi cables carries a low DC voltage while connected. ... If so, reset it to match the native resolution of your TV or video projector (such as 720p or .... Source Device:Any Blu-ray Player, DVD Player, Gaming Console (PS3, Xbox 360), ... Power cycle:Power off / Power on equipment (At the wall socket since some LCD's ...
HDCP / HDMI Handshake Troubleshooting and Guidelines
site.hdtvsupply.com/hdcp1.html
The hdmi cables carries a low DC voltage while connected. ... Source Device = Any Blu-ray Player, DVD Player, Gaming Console (PS3, Xbox 360), Apple ... Power cycle = Power off / Power on equipment (At the wall socket since some LCD's ...
Amazon.com: Customer Reviews: Belkin Conserve Socket ...
www.amazon.com/Belkin...Socket.../B003P2UMQ2
Amazon.com, Inc.I wanted to completely turn off my subwoofer amp, blu-ray player, PS3 and .... but my Mac uses next to no power and my PC normally gets shut down after use). ... I hereby give up any and all hopes regarding Belkin support. ... I plugged her television in to the main outlet and her Wii and dvd player into two of the other ones.
[PDF]Blu-ray Disc™ / DVD Player - Manuals, Specs & Warranty
https://docs.sony.com/release/bdps3100_bx310.pdf
Sony Corporationin this Blu-ray Disc/DVD player is harmful to eyes, do not ... be unplugged from the wall socket immediately in the event ... operating in conjunction with any other antenna or ... However, there is no ... as power-supply cord or plug is damaged,.
Jan 26, 2016 | Televison & Video
Hook up xbox 360 tv
What kind of receiver? Do you have anything else like DVD player going thru receiver? My receiver has 3 hdmi in and 1 out (to tv) so all those equipment would just go to "hdmi" on tv.
Another way to do it is put your tv on exterior audio... for all sound to go thru your receiver.
Jan 05, 2014 | Televison & Video
My xbox 360 wont work with an hdmi cable all i get is sound and the screen just says unsupport
that normally means that the TV doesn't support the software version...need to contact either the tv makers support number, or Xbox.com/support, and explain your problem.... maybe there is a setting on your TV that can change the setting for your hdmi input
Feb 26, 2011 | Microsoft Xbox 360 Console
Hd picture
Your TV does not support 1080p thats why, just adjust blu-ray and PS3 resolution down and it will work
Jun 01, 2010 | Sony STR-DG820 Receiver
Hi, i have a flx-2211b element electronics tv and I have a xbox 360 hooked up to it through a HDMI cable but the tv says unsupported mode. what do i do to fix it?
I have the same problem with my 360 i am just going to by a new tv i cant find the remote code. or any thing and the hdmi port don't work that's my answer this TV sucks and it is ****..
Jan 07, 2010 | Element Electronics FLX2211B 22 in. LCD TV
I tried to hook up my ps3 to my hannspree monitor
did you hook the dvd player or xbox 360 to see it if still works after ps3? if still no result, it's most likely that the motherboard in the lcd shorted out.
Oct 16, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
I have a xbox 360 that wont play any games but will still play cd and dvds what can i do
liamso that would be stupid what he needs to do is remove the cover to his xbox and gently clean the dvd laser reader. however, this doesn't always work so he can buy another xbox wich would be better than your ps3 idea because the xbox is cheaper!
Oct 14, 2009 | Microsoft Xbox 360 Console
TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Jun 18, 2009 | Televison & Video
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
Compatibility Issue with HDMI Switch?
anytime your talking about a switch your talking about a temporary connection. The issue with using a switch is that for HDMI you want best quality and you will not get that using a temporary connection. The unit may be recognizing a weaker signal and turning the port off. However since the output on that particular unit is 1080i you should be fine using composite, just get a nicer monster set.
Dec 26, 2007 | Samsung DVD-R135
Televison & Video Logo
307 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
