Question about GE DVLR223 Dryers
Dryer does not turn in when door shuts . its clicks when door shuts and does not start
    President:
  • 3,074 Answers
This should help, Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on Oct 16, 2010
Help I put a bunch of shoes and one pair of work boots in the dryer and had the bright idea to duck tape the door shut. We had some body lice come into our house so I was trying to heat treat the shoes!...
Maybe a belt or the start cap. The click is probably a relay switch. Will the drum turn by hand? Turn it on, spin the drum and close the door while its still spinning. If it starts then its the start capacitor on your motor. Most electric motors need extra juice to start. A capacitor is like a battery and can go bad after a while. It looks like a battery and should be mounted on or right next to the motor.
As it if you can fix this... that depends on you. Have you worked on dryers before? Do you know how to remove the panel from around the door with a putty knife?
https://www.youtube.com/watch?v=AgsOwIwoygc
Oct 24, 2014 | Dryers
Dryer has no power will not turn on
Is door shut good ? Check door switch push it in and see if you can hear it click. Check power at outlet then where it goes into the dryer. Check start switch and voltage coming out of the timer. Check voltage to motor. If voltage to motor you will need a motor.
Nov 11, 2013 | Whirlpool LER5636P Electric Dryer
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
Lights come on but dryer will not start. I hear a delayed clicking sound once pushing the start button. door is shut and lint tray is clean.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 30, 2010 | Samsung DV3C6BEW Dryer
Ever since the door was slammed shut, the dryer will not run. The panel lights turn on, and when "on" is pressed, it clicks but does not engage.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 31, 2010 | Frigidaire GLEQ2152ES Electric Dryer
I have model #110.76712645 The dryer does not
open the door and push on the door switch paddle,if it doesn't click the door switch is broken.when you open the dryer door while it's running the dryer should shut off,if the switch breaks the dryer will either not run or will stay running,if the switch is clicking and is good then you have a broken push to start switch.this is the button you push on to start the dryer,this could break in the on position.let me know what you find
Jul 14, 2010 | Kenmore Dryers
When turnng the turn on switch, the dryer does not start. If I applly pressure on the door, it will start, but as soon as I take the pressure off, the dryer stops
Is there anything obstructing the door? Can you visually see the door switch? When you shut the door can you hear a click from the door switch activating?
Sep 12, 2009 | Whirlpool Dryers
LER4634EQ1/Won't turn on
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Dryer starts on it's own when timer is turned or door is shut
its the door switch more than likely are less likely the push start button stuck
Mar 16, 2008 | Dryers
Dryer stays on for 3 secs and turns off; sometimes won't turn on at all.
sometimes the movement will cause the door to open, thus shutting off the dryer. Does the door shut tight when you close it? there is a little clip that if broken, the door will pop open easily. After it shuts off is it easy to start again?
Mar 12, 2008 | Dryers
GE DVLR223 Dryers Logo
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
