Question about Samsung LN46A530 46 in. LCD HDTV
I have a Samsung LCD TV LN46A530 that keeps clicking and recycling on and off. Where can I get a service manual or buy a replacement power supply and how much would it cost?
  • Rod Salvilla Oct 16, 2010
    You have not told me anything that I didnt know. I need to know a website link that I can get me a copy of the schematic diagram or service manual (as part of my original question). Samsung wont sell it to consumers.
    If you know of a speciafic part(s) on the power supply board on this particular Samsung model LN46A530 that is known to fail prematurely, I would consider that an acceptable solution from you.
    Thanks
  • 4,889 Answers
Like you said it yourself, the clicking noise is associated with the power supply. The clicking noise is actually relays shutting themselves off due to an overload on the line. Possible reasons include failed Voltage regulator ICs, resistors and/or blown capacitors. It might be easier just to replace the power supply board. It should cost you around 150$. If you can get me the part number off the power supply board I can find you a replacement. This is because different tvs of the same model no may have different versions of the same part so it is always recommended to order a part by part number.
Posted on Oct 16, 2010
    Genius:
  • 1,622 Answers
Before making attempt to buy another power supply board,,
its the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop, but if otherwise you can try ebay.com, shopjimmy.com. It's will cause
65 - 85 dollars.
Hope this help in solving the problem......
After replacing all capacitors on the power supply board,Tv still doesn't come on
if only a blinking indicator at the tv panel that was mean has an error detected by the main board. if no any power indicator then you have been already replaced bulging capacitors but still won't turn on. at this time you will need to have voltage checking using a digital tester, if their is an output voltages at the power supply board.
Jan 18, 2013 | Samsung LN46A530 46 in. LCD HDTV
My 42 in Samsung (LN46A530) TV is flickering when I turned it on and it stays for a very long time.
A lot of the Samsung's have a common issue, there is a jumper in the power supply that needs to be removed, Contact Samsung with the model number and they can tell you if your set is one, they were fixing this issue for free.
Dec 14, 2012 | Samsung LN46A530 46 in. LCD HDTV
Is the Samsung Ln46a530 dual voltage ie (110 America - 240 Europe)
The tv power supply board is not the problems,that can add a transformer to solved it easily.The problems are US and Europe uses a difference tv signal frequencies.The US,Canada and Mexico are using a NTSC signal frequencies.Europe,Asia,Middle East and Africa are using PAL signal frequencies.U must have a tv that call REGIONS free tv to work in Europe and US same time.If u just have a standard LCD or a Plasma HD tv buy it in the US for example will not work in Europe
Jun 09, 2011 | Samsung LN46A530 46 in. LCD HDTV
What is causing my TV to display inverted colors, like a negative photograph? The picture of my LN46A530 LCD TV has degraded an it looks like if I was seeing a negative photo.
TV display inverted colors, like a negative photograph because defective panel. Mostly from T-con board. Replace T-con board.
I hope that will solve your problem.
Thanks.
Mar 03, 2011 | Samsung LN46A530 46 in. LCD HDTV
I have a Samsung 52 LCD TV about 2-1/2 years old. Start clicking about 10-12 times then it turns on. today I turn it on and it just keeps clicking and will not turn on? any Ideas.
The power supply board it is dying and most likely causes by weak and dying capacitors parts bulges up or puffing up leaking.The power supply board,that the board where the power a/c cord plug into it.U have all the tools,understanding basic electronic also can do basic soldering work?Yes check the power supply board carefully replaced all dying to be dead capacitors parts or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 25, 2011 | Samsung LN55B650 55 in. LCD HDTV
Samsung lcd ln46a530 is having some difficulty turning on and when i does turn on the picture drops out( blank) but the sound stays on.
The tv have 2 long boards call the LCD inverter boards.These 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy these refurbihes 2 long LCD inverter boards for the replacement.
Oct 27, 2010 | Samsung LN46A530 46 in. LCD HDTV
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
My new samsung 400pxn wont turn on it just keeps on making a continues clicking noise every 2 to 3 seconds and the power lights flicks on and off
This tv still under warrenty?Call Samsung for service.Ur tv the power supply board is dead.That the board where the power a/c cord plug into it.That is ur tv power supply board and is dead.It must require replacing.Tries websites like Shopjimmy.com,ebay.com to buy a refurbish power supply board for the replacemnt,if the tv is out of warrenty.
Jun 17, 2010 | Samsung SyncMaster 400PXN LCD TV
Samsung LCD Television continually clicks until unplugged but won't turn on
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Jan 29, 2010 | Samsung LN46A530 46 in. LCD HDTV
Samsung LN46A530 46 in. LCD HDTV Logo
321 people viewed this question
Jerry Greenberg
Jerry Greenberg
