Question about Daewoo DVRS04 DVD Recorder/VCR
I have a DVB-T VCR/DVD recorder and have been using it for ages but suddenly it will not work unless we put in a code to disable the watershed parental lock, we have put in 0000 and entered it but it just keeps taking us back to the menu to enter the code in again and will not accept anything. We have tried reverting it back to the factory settings and trying again but have the same problem, any ideas?
5 Suggested Answers
SOURCE: parental code
although my situation was a bit different, part of msimeomix's solution still worked. after entering the password "3308," the screen went blank. i knew this parental code had worked but it would still not allow me to access the "setup" or "menu" options. i pressed "STOP" and then ejected the disc/turned the DVD player off. upon turning it back on and entering the password "3308" i was able to immediately press "PLAY" and it worked. enjoy the movie :]
Posted on Feb 15, 2009
SOURCE: My Daewoo DVB-T VCR/DVD Recorder has decided to
Default Serial is 0000
Hope that helps
Nigel
Gregory Audio Visual
Blackburn
Posted on Nov 20, 2009
SOURCE: We have a Daewoo DC DVB-T HDD/DVD Recorder. We
menu--hdd playlist--ok -select recording--select play then scroll down to dubbing--ok --add or scroll down to start dub.
Its not a problem
Posted on Jan 15, 2010
SOURCE: dvb t vcr/dvd recorder drvt 43 freezes after being plugged in
aewoo DVB-T VCR%2FDVD recorder freezes during recording from VHS to DVD
Posted on Mar 01, 2010
Have philips univerasal remote need codes for my panasonic dmr-ez28 dvd recorder
Panasonic DMR-ES30VS DVD Recorder/VCR Universal ...
www.fixya.com > ... > Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR, universal remote related issues. Getfree help ... My remote does not work anymore. what is the code for a universal remote? Thanks in ... Question about Philips DVD & Blu-Ray Players ... How do I getremote code for GE universal remote control Need remote code? How to ...
Philips Magnavox MWR20V6 DVD Recorder/VCR Remote ...
www.fixya.com > ... > Philips Magnavox MWR20V6 DVD Recorder/VCR
Dec 20, 2015 | Panasonic Televison & Video
Can I record a dvd on a dvd recorder from a vhs tape on another vcr? I had a dual dvd recorder but the vcr part is broken
Should be able to. Are you sure you are using a recordable dvd? Also, are you sure you put it in the recorder side?
Oct 02, 2014 | Televison & Video
Bush dvr3006 will play audio disks but wont play any dvd ! just says load for ages then turns off or no disk ! help please ?
These are the formats your DVR will or will not play.
  • Blu Ray Playback: No
  • Blu Ray Recording: No
  • Compact Flash Card: No
  • DTS Decoder: No
  • DVB-C: No
  • DVB-S: No
  • DVB-T: No
  • DVD Audio Playback: No
  • DVD Player / Recorder: DVD Recorder
  • DVD+R Playback: Yes
  • DVD+R Recording: Yes
  • DVD+RW Playback: Yes
  • DVD+RW Recording: Yes
  • DVD-R Playback: Yes
  • DVD-R Recording: Yes
  • DVD-RAM Playback: No
  • DVD-RAM Recording: No
  • DVD-RW Playback: Yes
  • DVD-RW Recording: Yes
  • DVI Interface: No
  • DivX Playback: No
  • Double Layer Recording: No
  • Electronic Program Guide (EPG): No
  • Ethernet: No
  • Firewire IEEE-1394 Interface: No
  • HD-DVD Playback: No
  • HD-DVD Recording: No
  • HDMI Interface: No
  • HDTV: No
  • IPTV (Internet Protocol Television): No
  • Integrated VCR: No
  • MP3 Recording: No
  • MPEG4 Recording: No
  • Memory Stick: No
  • Multimedia Card: No
  • Number of Scart Interfaces: 1
  • PCMCIA Interface: No
  • Progressive Scan: No
  • Real Dolby: AC3
  • Secure Digital Card: No
  • Show View: No
  • Smart Media Card: No
  • Super Audio CD Playback: No
  • Super Video CD / Video CD Playback: No
  • Table / Portable: Table
  • USB Interface: No
  • W-LAN Connection: No
  • xD-Picture Card: N
May 24, 2014 | Televison & Video
My Panasonic DVD+VHS recorder has suddenly stopped recieving a signal. Aerial still works from dvd recorder to TV.
No signal from this combo unit can mean either one of 2 things; the program information didn't update correctly while unit was in standby, so some digital channels may be missing or scrambled, or you have selected a HD channel by mistake during use (this series does not have a HD tuner, it is only SD which would also produce the no signal issue).
Going on the first possibility, you can reset the unit back to factory default. To do this, while it is on, press and hold (on the front panel, not the remote) CH UP and CH DOWN buttons together until 'SETUP' appears on the display. Once setup begins, and the unit searches for DVB channels, release the buttons. With the remote, follow the subsequent options afterwards, when prompted. Check other menus, then exit. This should restore your unit to all SD digital channels available.
Assuming the tuner works generally, this reset procedure should help (it works perfectly for Australian models of this series).
Apr 23, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Now that we are on digital will the SD-37VB dvd vcr recorder work or do I have to alter a setting to make this happen
If the unit has a built in analogue tuner, the unit itself will still operate as normal, but without the built in analogue channels - to record a TV show, you would need to connect an external set top box to it (SD or HD - or both).
In other words, apart from a separate set top box, if required, there should be no need to change any of the unit's settings if it works as is. I do not believe this model has a built-in digital (DVB) tuner.
Apr 13, 2011 | Toshiba SD37VB DVD Player / VCR Combo
Dvb t vcr/dvd recorder drvt 43 freezes after being plugged in
I have the same problem. Telephoned Daewoo and they said that there was a download available that will fix it. Unfortunately, the contol keeps freezing so I can't do this. Therefore, I have contacted the retail supplier and they are sending a replacement and also letting me have relevant info to send the defect one back. Hope this helps.
Jan 25, 2009 | Daewoo DVRS04 DVD Recorder/VCR
I have a V3650 DVD Player, can i copy my old VCR tapes to DVDs ?
this player will not record copy garded material (this will not work! and yws the life of a VHS Tape is only about 15 years!
Dec 09, 2008 | Samsung DVD-V3650 DVD Player/VCR
Recording DVB on this DVD recorder?
Have sorted this problem now, I purchased a SCART DVB TV Unit from Freecom, this did not work at first connection, but I then realised that it had to work as RGB into the SCART plug on the DVD, once I set the unit to RGB, all was fine.
I can now record Freeview on my DVD fine.
I do however have one prblem which this will not overcome, that is the addition of yet another remote control !!!
Byeeeeeee..
Nov 30, 2007 | Pioneer DVR-220 DVD Recorder
Daewoo DVRS04 DVD Recorder/VCR Logo
60 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
