Question about HP LaserJet 4250n Printer
Size mismatch Printer says size mismatch in tray 1. How do I resolve this?
  • Anonymous Mar 12, 2014
    I do I fix on a Xerox 6605 tray 1 paper mis match error
  • Anonymous Mar 21, 2014
    024-958 SMH size mismatch error in the printer
  • 4 Answers
First cancel all print jobs from the attached computers. In the control panel you can asign the paper size for each tray. These setting also have to match the computer's settings for this printer. You'll find the information on this printer from the printer;s file under properties.
Posted on Jun 15, 2008
Printer alarms us when a print job has been snet but wont print unless we manualy push the paper size on the printer
You have a mismatch paper size. Document is not same as paper you have in copier. Try printing 8 1/2 by 11 document if doesn't print check printer preferences and adjust settings. Check copier paper trays make sure don't have special settings on them
Nov 28, 2013 | Ricoh Office Equipment & Supplies
When i try printing with my sharp ar-m205, it automatically reselect bypass tray and gives error "check bypass tray: out of paper or missfeed". But the tray i originally selected is tray 1.
Size mismatch between your print request and the size specifed for the paper in the tray. these trays do not auto-read, you have to tell the copier what size is in the tray
Nov 01, 2013 | Sharp AR-M205 Copier
Feed from tray problem
it will always try to pull from the MP tray if it has a media size or type mismatch even if you default to tray 1. Check your media size and settings
Aug 10, 2013 | Kyocera Office Equipment & Supplies
Paper mismatch displays on the printer. I have to pick the paper size manually on the printer to print. How do I stop this error?
Make sure that the paper size of your document, and of the tray are set the same - if there is any conflict you ned to resolve it each time.
Jul 01, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
M20/Ms0i WorkCentre display "Paper Size Mismatch"
the settings on the print driver and the machine do not match.
  1. ress the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until the required paper tray is displayed; either [Tray 1 Size], [Tray 2 Size], or [Bypass Size].
  4. Press the [Enter] button.
  5. Press the [Left] or [Right] arrow button until the paper size loaded in the paper tray is displayed.
  6. Press the [Enter] button to save the setting.
  7. Press the [Stop] button to return to the Standby mode.
Jan 28, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
Jan 20, 2010 | HP Photosmart C4580 All-in-One - InkJet...
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Printer will not kick out document automatically, attention lite keeps flashing. tray 2 selected but always defaults back to tray 1
Sounds like you have a mismatch in the paper you are trying to print on and the paper that is loaded in the printer. HP printers look to feed paper from tray 1 anytime the computer settings don't match the paper loaded in tray 2. Tray 1 is the multi purpose tray and prety much any size paper can be loaded in tray 1. Double check your document settings and double check the paper size loaded in the paper tray 2 and make sure they match. Also try printing a different document to see if the error persists. If it does this on everything you try to print you should also double check teh rear guide in the paper tray. There is a rear guide in paper tray 2. If it slides back too far it will make the printer think that paper longer than 8 1/2 x 11 is loaded. Push the paper all the way forward in the tray and push the rear guide until it is snug with the tail end of the paper stack.
Nov 01, 2009 | HP LaserJet 4700 Printer
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
HP LaserJet 4250n Printer Logo
5,006 people viewed this question
Ben Johnson
