Question about Gateway FPD1960 19" Flat Panel LCD Monitor
My monitor won't even turn on...press the power button and...nothing. Do I need a new cord?
    Master:
    Sergeant:
  • 381 Answers
Yes try a new cord. even a kettle lead should work.
or take out pc cord to test it
Posted on Oct 16, 2010
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
My hp touchsmart310 PC will switch on but there is nothing on the screen ?
You can perform these steps even though the screen is blank.
  1. Turn off the computer, and then remove the power cord.
  2. With the power cord disconnected, press and hold the power button for five seconds.
  3. Reconnect the power cord, and then turn on the computer.
  4. Repeatedly press the F10 key about once every second for five seconds after turning the computer on.
  5. Wait five seconds.
  6. Press the F5 key. This restores the default settings of the BIOS.
  7. Press the Enter key. This accepts the changes.
  8. Press the F10 key. This opens the Save and Exit window.
  9. Press the Enter key. This saves the changes, exits the BIOS, and then the computer restarts.
  10. After the computer restarts, the screen should display the HP logo.
Hope it helps!
Aug 11, 2014 | HP Touch Smart Desktop Computer "brand...
My HP Pavilion M90 monitor won't turn on. Every time I press the on button I hear a clicking sound from the back of the monitor. It sounds like it's trying to power up but it doesn't do anything. Is there...
Hello
Do a hard reset on the laptop by removing all cords and connections from the computer, including the power cord. Turn the computer over and slide the tab next to the battery, then lift the battery out of its compartment.
Eject any SD cards currently inserted in the SD card slot by pressing on them, then remove them from the slot completely. Hold the computer's "Power" button down for at least 15 seconds, then plug the power cord into the computer and turn it on.
Watch to see if the LED lights near the "Caps Lock" and "Num Lock" illuminate. If the lights do not turn on and the computer's screen remains blank, inspect the power cord and AC adapter for damage and replace them if necessary.
Leave the power cord plugged into the computer and snap the battery back into its slot. Allow the computer to sit for at least 30 minutes, then unplug the power cord and press the "Power" button again to see if the computer will turn on.
Plug the power cord back into the computer and try to turn it on again. If the computer turns on, replace the battery with a new one. If the computer still does not turn on, take the computer to a repair shop.
Oct 04, 2010 | HP Pavilion M90 Monitor
I have a lcd monitor problem, it wont turn on. the little light thats suppose to light up when you plug the monitor doesnt light up.. when i press the power button the green light appears for a sec and the...
sounds like a power issue with the monitor. try to remove and reconnect its power cord. If same thing happens, try using a confirmed working power cord like the one you use with the computer and make sure you test it out using a confirmed working power outket. If it has the same issue, would mean you need to get a replacement monitor. Refer to the vendor if it is still in warranty.
Aug 31, 2010 | Computers & Internet
Hello we have a 19inch HP monitor that doesn't power up, even with a new cord and different outlets in the power strip.
after connecting it to the circuit correctly> try pressing the power button that might be either on the right top or side> if the power button doesnt turn blue> the monitor has gone bad
Oct 08, 2009 | HP Computers & Internet
Moved computer to new location. rehooked all. monitor wont start
Without seeing your make or model on you monitor it is difficult to give you any advice.
But with that said.. If your monitor is a flat screen there is a power cord that plugs into the wall the cord is connected to a small box (power converter) out of the box is a small connector that goes into your monitor. It is small and you may have to turn you Monitor over to see exactly where it connects.
Your computer will work whether or not you have Internet service.
Sep 08, 2009 | Star Logic 17" LCD Monitor
Acer AL1916 can't start
If you press the power button and nothing comes on at all then something isn't providing power to the laptop as it should and you may likely need to replace the battery or the power cord.
Find a replacement battery. Change your battery with a new one then plug it up and turn on to see if this works.
If replacing the battery doesn't work then replace the power cord and trying turning it on again. If this doesn't work either, you have a more serious issue going on.
Not too long ago, I was on vacation, my laptop had been working fine until suddenly it wouldn't come on at all. I went into the office to grab a new battery and power cord. (I work on computers so I had spare parts in my office/Tech Room.)
I got home and replaced the battery then tried to turn it on using the old power cord...didn't work. This was a brand new battery so now I knew that I could rule out the battery as the issue...the only two things left to troubleshoot were the power cord and the laptop itself.
I put my old battery back in the laptop then tried to turn it on using a different power cord and it worked. I didn't need to replace my battery or laptop. The power cord had failed.
I hope that your issue is as simple as this solution. Try confirming whether your battery and power cord are still working...you may just need to replace one or the other.
Thanks for using Fixya.
Share your experience by rating this solution.
Mar 29, 2009 | Acer AL1916B 19" LCD Monitor
Acer Monitor: X193W Well, nothing wrong with it... it is turning it on. When I press the button to turn it on, it don't work. Would I have to get another monitor or try find another power cord? Should I...
first you need to try other power cord from other monitor and then to try your monitor to other computer if this dont work then here it is a problem with the supply and could fix only in service .
Dec 10, 2008 | Acer X193W LCD Monitor
How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Oct 07, 2008 | Sceptre DCL9a
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
