Question about Asko T761 Electric Dryer
I have a T760 ASKO model. The dryer turns on and spins but very slowly. It will not turn any with a normal load of clothes. Help!! what is possibly the problema?
    President:
  • 1,140 Answers
It sounds like the drive belt is worn and slipping. It's OK when it's empty (although slow) but as soon as you put in under any load (no pun intended) it doesn't run.
It could also be the motor/bearings, but I'd start by checking the drive belt between the motor and the drum. You'll need to take the back off the dryer to do this. Make sure the power is off first!
Please rate this solution if you find it helpful. Thanks.
Posted on Oct 16, 2010
    President:
  • 3,074 Answers
This may or may not help, Tim:
http://forum.appliancepartspros.com/dryer-repair/1854-dryer-drum-turns-slowly.html
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Mar 31, 2015 | Asko TL751 Electric Dryer
Asko T760 Dryer - Computer Screen Blank
you have either a frequency related issue or there is a lot of t.h.d. total harmonic distortion on the line, this will raise cane with electronics, I would try a power line conditioner on the dryer power circuit
Jul 30, 2009 | Asko T761 Electric Dryer
Asko W640 - sporadically says motor fault and won't run, or, won't stop running, gets stuck on the spin cycle. We've had the motor fault problem before, but this "running on" issue is...
I would say the won't-run problem is separate from the run-on problem. You can live with the run-on problem -- probably a fault in the controller. Unless it's a faulty code, the motor-fault light probably means the motor is overheating. That can be caused by anything that causes it to work hard, such as a stuck pump.
Nov 26, 2008 | Asko Washing Machines
I have an asko dryer model t760 that overheated the other day. it did finally trip the overheat protection switch on the back, but it did get hot enough to distort a few plastic pieces and put flat spots...
Try taking the lint filter out and gently washing it with a soft scrubber. The screening is very fine and it might look clean to sight but might still need a more thorough cleaning.
Aug 25, 2008 | Asko Dryers
Asko Dryer won't spin...need to tighten belt
Does the Motor turn... We have had many motors with bad capacitors .. check the white capacitors for cracks or metal coming out of it...the motors will run with out a load on the but put a few clothes in the drum and they will just hummm..
Jul 19, 2008 | Asko T721 Electric Dryer
Asko t760 display panel
My Asko T761 had the same problem, power button lights up but the LCD panel if off. This is not the fuse becuase I replaced with "new fuse replacement kit" provide by Asko but this did not solve my problem. All I needed to do was press the "reset button".
Feb 08, 2008 | Asko T761 Electric Dryer
Asko T761 Electric Dryer Logo
149 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
