Question about Royal MS 25 Typewriter
I have a circa 1940's-50's Royal Desktop Typewriter. The ribbon that was already on it was rather worn and severely faded so I bought new ribbon for it. The only available ribbon was a red-black silk inked ribbon that is actually meant to be used with Smith-Corona typewriters made after 1963. But from what I've seen, the problem isn't the ribbon (even though I had no problems before I switched the ribbon out) but the issue is the typewriter itself. The spool holders are acting a bit tricky; when I flip the switch to have the ribbon change direction in output, only one of the spools does anything. For example: The right spool will output more ribbon as I type, but the left spool won't move at all; and then when I flick the switch again to change directions, the left spool will output ribbon but the right won't budge. Meanwhile I've been typing on the same piece of ribbon for so long that I wore a hole in it. I've taken the spools out and can see that even with them gone, the knobs they sit on do the same thing, only one moves. I'm not sure what to do, help!
  • Royal Master
  • 3,594 Answers
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
Posted on Oct 18, 2010
Royal safari portable typewriter letters ghosting
Usually you are striking incorrectly snap the keys and get off of them. you holding the key down too long.
Jun 28, 2016 | Royal 1966 Safari Portable Typewriter 8247
I have a manual desktop circa 1940s royal typewriter. Bought it from a professional online who claimed it worked, everything looks good but the carriage and ribbon will not move. Tried messing with the...
most royal portables have a locking lever to lock the carriage in the center position try looking on the right side near the lower edge of the carriage
Nov 16, 2014 | Office Equipment & Supplies
I have a circa 1940s royal typewriter. Bought it from a professional online who claimed it worked, everything looks good but the carriage and ribbon will not move. Tried messing with the margin buttons but...
Sometimes they had a carriage lock for transporting it. Check for a little lift up lever thingy at the base of the carriage on the bar that goes across from one side to the other. Or just check around for any little levers that hold the carriage in place.
Cheers
My Dad has a Royal TA memory typewriter. He tells me it is typing every other letter. It's not double spacing his letters..it's skipping every other letter. He also says it's making a clickity clack...
It sounds like the ribbon is twisted and interfearing with the P/W Try installing a new ribbon and check the P/W for bent or broken spokes.
DickyO
Mar 11, 2011 | Royal PowerWriter Typewriter
How to replace ribbon on Royal Apollo 10 elec typewriter???
The cover either pulls up straight or there is a release lever in the front part of the cover that pushes.
Dec 15, 2009 | Royal Office Equipment & Supplies
The keys on the left side of my circa 1933 Royal typewriter gets stuck on the ribbon everytime. Also my ribbon doesn't advance. Help?!
Hi:
The most likely problem is there is dirt inside the ribbon basket. This is the area where the type bar (this is the bar with the actual letter on it) ends. They all fit into a semi circle area. If you can find something very narrow and thin with a hook on it you can use it to clean out the areas where each type bar goes. Then try to lightly lube the entire basket right where the type bars pivot with something light like sewing machine or 3 in 1 0il. As far as the ribbon reverse goes it might be as simple as making sure that the ribbon is being fed through the ribbon reverse forks which are usually located left of each ribbon spool.
Good luck
Andrew
Jun 28, 2009 | Royal ET510 Typewriter
Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Apr 09, 2008 | Office Equipment & Supplies
Royal MS 25 Typewriter Logo
313 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
