Question about Garmin nuvi 1390T Car GPS Receiver
My garmin 1390t gps has no satellite sign! Why?
4 Suggested Answers
reef runner
  • 7 Answers
SOURCE: Garmin GPSmap 76 not acquiring satellites
I had the same problem? GPSmap76S was hung up trying to AutoLocate. It just couldn’t find itself, and it just stopped working all of a sudden one day, while I was traveling. I spoke with Garmin about the problem, and they advised me of an ongoing problem with WAAS. I was told that I should "Disable" WAAS, because the signal from the WAAS satellites had been changed by the government, and Garmin had not yet put out a software update to address the problem, on the 76 units, anyway. Also said that an update "should" come out, in the future, however, no commitment or promise on that. Evidently, once your unit hits one of the WAAS signals, it scrambles up the receiver in the GPS, because mine sure went crazy. The support guy also said, that if this did not correct the problem, I might also want to try a "Master Reset". So here’s what happened.
I disabled WAAS, but this did not correct the problem. The unit was still lost out there somewhere, trying to AutoLocate, so I ended up doing the “Master Reset”. Please read up on this procedure before trying it, and understand that you “will loose” any settings that you might have made to the GPS, along with all waypoints, routes, tracks, etc., however, my maps actually remained in tact? This procedure will actually set the unit back, just as it was when it originally came from the factory. Once completed, you will then have to allow the unit to initialize it's self again, just as you did when the unit was new. If you have forgotten about doing that, it simply means that you need to set the unit outdoors and leave it “on” for a while (15 – 20 minutes), until it actually AutoLocates it’s self, or locks in on your current position. Once this is done, re-do your setting preferences, back to the way you had them before the Master Reset. At the very least, you’ll have to re-set it to the correct time zone, and tell it about daylight savings time. Note: It’s a very good idea to go thru first, and jot down your page settings and main menu settings, before doing this procedure, or the screens may not look familiar to you, once the unit resets. You think you’ll remember them all, but you won’t. But whatever, once you have done the “Reset” and “Initialization”, you must now hook the GPS up to the computer and reload your waypoints, routes, etc, back to the GPS. You did have them saved on your computer, didn’t you? Hope so… If so, you should now be good to go…………….
My unit now works like a champ, good as new, just not as accurate, due to WAAS being turned off. I still don't know if the WAAS issue, was part of the problem or not, but I do know that the Master Reset got the unit back to working immediately, allowing it to locate itself almost instantly. What a relief…………..it’s a little work, but it takes much less time than it took you to read this post…………..
Hey, when all else fails, call Garmin 1-800-800-1020. They are good guys and willing to help, in fact, I would advise you to call them before you do anything, so you can describe to them, exactly what your unit is doing. I am only relating my situation and what happened to me. Your situation may be different…….
Posted on Dec 13, 2008
bbl242003
  • 1637 Answers
SOURCE: Hello ! i would Like To Know, How To Do A hard
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Posted on Jan 21, 2011
expat53
  • 5 Answers
SOURCE: unlock garmin 1390t gps forgot
    • 1 Enter your four-digit personal identification number that you used to lock your Garmin GPS. When your Garmin GPS is locked, you need to enter the four-digit PIN every time you turn the device on.
    • 2 Drive to the security location that you set when you locked your Garmin GPS. Turn your Garmin GPS on and pull the GPS antenna up so that your GPS is able to acquire the satellite. Once your GPS recognizes that you are at your security location, it will unlock itself.
    • 3 Contact Garmin if you forgot your PIN and security location. You will need to send your GPS to Garmin to have it unlocked. You will also need to send a valid product registration or proof of purchase for Garmin to unlock your GPS. Call Garmin at (800) 800-1020 and get the shipping address and specific instructions from an authorized Garmin representative.
Posted on Jun 09, 2011
Garmin nuvi 1390t won't read or recognize microsd
The 1390t works with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it will not work in older devices.
You need to go with microSD cards, 2GB and smaller.
Feb 09, 2012 | Garmin nuvi 1390T Car GPS Receiver
How do I restore the qwerty keyboard to my 1390T?
Contact Garmin at https://support.garmin.com/support/searchSupport/escalateForm.htm . They will send you a zip file with the complete keyboards folder and directions to restore to your unit. Mine was missing altogether after I lost the maps too. It was easy to copy to the gps unit and now the qwerty keyboard is back again.
Jun 17, 2011 | Garmin nuvi 1390T Car GPS Receiver
Unlock garmin 1390t gps forgot 4 diget pin
Jun 09, 2011 | GPS
Distance to intersection or destination is off by 20-30 meters, how can I correct this?
Hi
connect your gps to your computer and run the garmin web updater program (free from garmin).
Make sure you have all the firmware updates as every now and again they readjust the satellite information to correct position errors.
Please dont forget to vote if you liked my answer
Many thanks
Feb 13, 2011 | Garmin nuvi 1390T Car GPS Receiver
My garmin Nuvi 1390t just started not showing roads other than main highways
I would check your Avoidances in Navigation.... to do that go to Tools....Settings....Navigation..... Avoidances..... see what is checked to avoid and uncheck it
Oct 23, 2010 | Garmin nuvi 1390T Car GPS Receiver
Hello.How do I register the 1390T with garmin?Thanks. Brian.
Click on this link to register your Garmin Device:
https://my.garmin.com/mygarmin/marketing/register.htm
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 07, 2010 | Garmin nuvi 1390T Car GPS Receiver
Got it for Xmas-just turned it on and it won't get a satellite signal...what gives ?
Hi.
Try resetting the Garmin Nuvi (access maintainance mode).
If that does not fix the problem, then the unit may be faulty. In that case contact Garmin at the number that you find on the owners manual to get the unit replaced.
Here how to reset the Garmin: How To Reset Garmin Nuvi GPS Device
Jan 05, 2010 | Garmin nuvi 1390T Car GPS Receiver
Garmin nuvi 1390T Car GPS Receiver Logo
146 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
