Question about Sharp 25N-M100 25" TV
Use following steps to reset channel, but I lost the sound 1. Unplug TV 2. Press Channel up and Volume up at same time, while plugging TV back in (two person job - it will pull up a service screen) 3. Press Channel up and Chanel down at same time. (Access to menu screen) 4. Use Volume up and Volume down to switch between menu options. We finally found the EZ set up screen.
    Welcome Back:
    Visited the website for 2 consecutive days.
Img{-moz-force-broken-image-icon:1;} Same no sound issue happened to me; except I stopped at adjusting vertical size (unfortunately it seems horizontal cannot be set thru service mode; which was my original intent). Complete lost of sound signal processing; oddly enough speaker volume leveling did worked. (Eg, audio-in woks; so a big WTF?!) I suspect something to do with not recovering properly the data bus from muxing the volume input keys; ie, some kind of weird service/back-to-normal switch bug. I've waited for a couple of days for the damn thing to unlock itself out it (like some stubborn transistors seem to do); but to no avail. (BTW, only dif between TVs is that mine's a slightly smaller and cheaper model, a 19U-M100S; a minor branch out of the main line.) I'm afraid something did "burned out" and that the only real fix is to actually change the "defective" part. Had I known silly sh1t like that could happen, I obv would've not messed with it to begin with. It's just ridiculous, and lame. Besides being obsolete. In any case; I also think it's nowadays better to get a (full) digital one (wisely cost effective).
Posted on Mar 15, 2011
My Emerson TV is stuck on number 1 channel how do I get it to go to other channels?
Need to go into the menu look for the channel setup then check the skipped channels make sure channel 1 isn't the only Channel not checked also Look at Your scanned channels in the channel list how many do you have is channel 1 it ? you may need to rescan your channels . If the TV worked OK before but Not now try resetting Your TV , BUT do this last as You will need to reset all the parameters in Your initial setup as well as rescanning channels also the Volume may blast you after reset I always install a set of earphones in the Audio phone jack first . To reset the TV Unplug it from the back of the set wait 30-40 seconds reconnect the plug while holding the Power Button Reset Your Options and Settings then Rescan your channels Don't forget the volume and to unplug earphones Good Luck
May 18, 2016 | Emerson Televison & Video
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
RESETTING THE LAMP TIME
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
POWER
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
HOW DO I RESET THE LAMP TIMER ON A SONY KDF55WF655
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Jun 30, 2011 | Sony Televison & Video
I am not getting picture on my TV it stic on only one channel we are chengiong channel but same sound is comming also we are getting a blue coloured K on right hand side of TV
That blue K means you are in the service mode. Unplug your set and wait 30 seconds. Then at the same time you plug it back in, you need to be holding the volume down button and the input button.
The TV should turn back and the blue K should turn pink. Once this happens, press the volume and channel down button at the same time. A menu should come on the screen. With your remote, press the up arrow to reach the nest page. The first option should say INIT. Arrow to the right and hit enter. In a few seconds your screen should turn green and say success. Unplug the TV and wait 30 seconds. Plug the set back in and turn on your TV. You can then set your set back the way you want.
May 04, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
We have a VIP 722 and the second channel is now without sound. We have sound on channel 1 but not 2. Any ideas?
Step 1: Check that TV or Stereo is not muted
Make sure that your TV or Stereo has not beed muted and that the volume is turned up loud enough to hear.
Step 2: Reset Receiver
If the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
Please note: It may take up to 5 minutes for the reset process to be completed.
Step 3: Check Receiver-to-TV Configuration
Check that the wiring between your DISH receiver and your TV is configured properly.
Step 4: Secure Receiver-to-TV Connections
Check that the connections between your DISH receiver, your TV, and any component(s) (VCR, DVD Player, etc.) in between are secure.
Mar 10, 2011 | DISH Network ViP722 DTV Receiver /...
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
With my starview 3 all of sudden my sound is distorted
To get back sound channels ect just select the channel in question press menu,
select installation, select manual scan, click ok on down frequency.
It'll now scan for channels when its finished exit back to normal
tv viewing screen go to the end of your channel listing and the desired channel will be there with sound.
This can be done on any channel with no sound by just selecting that channel following the instructions above.
Hope this helps
Feb 25, 2009 | StarTech.com StarView SV211K 2-port KVM...
No sound on my Sanyo LCD 32" flat screen tv
I had this same problem this morning. Luckily, when I reset the whole thing and did the channel search again the sound returned. I have no idea why it fixed it but it did. Hope this helps you.
Feb 12, 2009 | Sanyo DP32746 32 in. LCD Television
Time TV
By saying that volume and picture controls work, do you mean you can access the TV's onscreen menu? If so, you may need to re-scan for available channels if you are using the TV's internal tuner. If the memory of those channels has been lost, the TV does not know where to "look" for a signal. You may also need to perform a power drain:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on. After this step, try the channel scan again if it didn't resolve the issue the first time.
Oct 16, 2008 | Televison & Video
No Remote - Need to access Menu
We had the same problem - this worked for us:
1. Unplug TV
Somehow in the process we muted the TV and are now working on getting the sound back. :)
Good luck to you!
Apr 28, 2008 | Sharp 25N-M100 25" TV
Sharp 25N-M100 25" TV Logo
204 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
