Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Screen seems dirty from the inside. How do you clean?
  • bulldozas Oct 16, 2010
    Sorry, but clips are not obvioius...cover seems to be held by screws or bolts.
  • 100 Answers
Around the rim of the screen there is a plastic cover you can pull this off there are clips holding it then you can take protection screen off and clean
Posted on Oct 16, 2010
    Sorry, but plastic cover seems to be attached with screws, not clips.
Lg wd 1049c
There are cleaners you can get at the grocery store in the laundry soap section.
Jan 23, 2014 | Washing Machines
Wheels not turning.......... gear? will move slowly in pool but only seems to move with the thrust of water........
Check the metal debris screen inside the fitting that connects to the pool wall to make sure you have good pressure. If dirty then clean the screen. Then check the hose to make sure there are no holes. Look at the inside of the front wheels to see if the teeth are stripped. If they are then switch the back wheels to the front. If they havent been switched before the back wheels should have good teeth. If there is no inline metal screen on the feed hose then the jets inside the cleaner could be clogged with seeds or some type of debris. Also could be a bad internal gear or bearing that is seizing up.
Aug 07, 2010 | Pentair White/Gray Legend Platinum...
My screen has a green hue and cannot seem to correctit is a protable dvd with lcd screen
One of the possible things:
a loose/bad/dirty connector contact or a bad solder contact inside the case (possibly the LCD screen connector at either side). This may show up as the problem you're having with your unit. Checking and/or cleaning/resoldering the connector pins might solve this.
It may also turn out to be something else (like a bad output from a chip or a bad component inside or near the video section, which might require component replacement.
regards
3rq8 (Triarcuate)
Jul 22, 2009 | GPX PD808B Portable DVD Player with Screen
Cleaning the inside -Pentair 320 Chlorinator Model R172276
their is a set screw in the side of the chlorinator towards the bottom (you should see a little hole in the side of the chlorinator near the base). remove that screw and the chlorinator will unscrew from the base.
Jul 13, 2009 | Pentair 2.0 Hp Whisperflo Pump
HD-56G787 JVC HD-ILA Help me clean the mirror!
pop the front strip under frnt of screen off. remove screws around back edge off screen and under the frnt of th screen. Usa a micro fiber cloth to clen screen.
Apr 25, 2009 | JVC HD-56G787 Television
Mitsu 65" DLP-picture seems washed out
Most likely cause of your trouble is dust on the small mirror inside you set. Your DLP set has 2 mirrors not including the DLP chip itself which has about 500,000 tiny mirrors. The 2 mirrors reflect the DLP chip image to the screen you view. The first is the main suspect it's about 4inches by 7inches. It's mounted on the bottom center facing backwards. This mirror faces slightly up and somtimes after time dust, smoke, dirt settles on it . The second fills the space of the entire back of the cabinet but it faces down and takes alot longer to get dirty.
The compartment is sealed but dust seems to find it's way in. If you remove the screws that secure the screen assembly from the top , sides and bottom. Make sure to have a friend available the screen assembly is delicate when it's not mounted to the cabinet. You can remove and clean the mirrors. These mirrors are glass and you can use glass cleaned. Don't use glass cleaner on the screen it's plastic. You can clean it if necessary with plastic cleaner only. Probably not needed.
Good luck.
Apr 23, 2009 | Mitsubishi Televison & Video
Seems locked up?
this one is a good suggestion,if you can only dismantle the psp yourself.just clean those ribbon type cables inside.they are coated with carbon contacts at the end. when this contacts are dirty the control will not work.just use a piece of earbuds for cleaning.dont use any type of liquid otherwise you will just erase the carbon.hope this one helps
Dec 25, 2008 | Sony Limited Edition PSP Daxter...
Inside the cabinet projected on the screen?
well . there are 4 things that can cause this..
1= the outer screens could be dirty.clean with screen protector cleaner.Spray on cloth and not on outer screens.
2= outside lenses of picture tubes could be dirty.Unit can be opened .Outside lenses can be cleaned with a lens cloth .Do not use paper towels or cotton as this my scratch surfaces of lenses.
3= inside of picture tubes could be dirty.This should be done by a repair shop only(dirty coolant inside tubes)
Dec 28, 2007 | Philips 55PP9401 55" Rear Projection...
Inside screen seems to be getting dirty
I had the same problem until I removed the screen and cleaned the front mirror with a static feather duster. First, turn OFF power. Second, remove screws on rear at top and on both sides of the screen. Third, remove speaker grill. Fourth, remove screws on each side of the screen where screen meets the speaker area. Fifth, remove two screws in center area of speaker area under screen. Sixth, lift screen up and away from set housing and use a duster with a two to three extension and GENTLY wipe the noticeable dust layer from the front tilted mirror located behind the screen at bottom of screen. Seventh, do everything in the REVERSE and you're done. If you need to replace the lamp, now's a good time to do so. Also you should clean the dust filter located behind an access door on the rear (right hand side as your are looking at the rear) with a handheld type of vacuum device.
After I completed ALL of the above procedures my WD-62525 was better than I remember. I bought it in 2005 and the picture quality has never looked so good.
The screen is as light as a feather but 62" is awkward. It is recommended you use another person to hold the screen but I work best alone and it was a breeze.
GOOD LUCK.
Dec 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Picture looks dirty in corners
hi there, maybe you do have some speaker, transformer or any magnetic near the unit that magnetise the screen. remove any magnetic matterials near the screen and it will come back normally. the cleanning is behined only the screen by brush. ty
Oct 15, 2007 | Toshiba 61A60 TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
