Question about Garden
How do i get a user manuels for the imperial valet timer/ sprinkler timer
2 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: Bought a new home and
I'm a sprinkler contractor and as far as I know that controller has not been manufactured for many years. Set the small dials for the time that you want each zone to run. Set pins on days you want to water. Set a pin on the start time for the cycle that includes all zones. Set the time and day and hope all of the motors work.
Any other questions, let me know.
Gary
Posted on Dec 14, 2010
Imperial valet timer
Big box stores and sprinkler supply stores.
Aug 22, 2014 | ORBIT UNDERGROUND Sprinkl pop-up 4 adj"
Nelson water timer instructions
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Link has all sprinkler timer manuals available online 2012.
Probably does not include older timers since manufacturers post recent manuals, with expectation that today's sprinkler timers do not last long. Except for Intermatic 120V-240V sprinkler timers that are made to last decades and have replacement parts.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Add a comment as needed.
Jun 06, 2013 | Hardware & Accessories
Orbitz sprinkler timer
What are you controlling?
Copy following link for Intermatic timers.... install 48 consecutive 156T1950 trippers on the dial, and timer will be ON for 12 hours. Timer arrives with 12 trippers, and you order 3 more packs for 48 trippers.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Add a comment and describe what you are using timer for.
More sprinkler timers:
Link above includes 'all' sprinkler timers on market today
Jun 03, 2013 | Electrical Supplies
Orbitz irrigation timers
Intermatic sprinkler timers, 12 hour on-off is possible plus day skipper option, and rain gauge connection etc::
Link above includes sprinkler timers on market today
T8845pv
You have 120Volt Intermatic sprinkler timer with 24Volt output.
Copy following link for setting sprinkler timer:
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
Copy following link for wiring Intermatic sprinkler timer:
Add a comment
lllllllllllll
May 25, 2013 | Intermatic T8845PV - Sprinkler-Irrigation...
The timer no longer plays all 3 programmed zones. It play only one.
Three things to look for:
1) If sprinkler turns on-off but doesn't advance to next zone, then Sprinkler Valve is suspect, and timer is good.
2) If sprinkler stays on all the time, or never turns on, then Timer is suspect.
3) If sprinkler turns on-off, but leaks when it's supposed to be off, then Sprinkler Valve is suspect, and timer is good.
Jun 24, 2011 | Intermatic T8845PV - Sprinkler-Irrigation...
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
RE: Intermatic model T8845PV used for a sprinkler system. The system works fine on manuel but does not come on on the days selected when on automatic. Day pin is pulled out and aligned with 12 0r 14...
1) Check that yellow timer dial is rotating and keeping correct time > if not, then buy new clock motor
2) Check that silver tripper pin is installed at 12 midnight. This tripper advances day-skipper wheel each day at midnight. Check that tripper is advancing the skipper wheel.
3) Rotate skipper counter-clockwise until current day lines up with 14 arrow.
4) Check gold tripper pins are pushed in place.
Open following links for parts list
http://waterheatertimer.org/pdf/Setting-Intermatic-sprinkler-timer.pdf
Apr 03, 2011 | Intermatic Hardware & Accessories
Bought a new home and need a manual for our imperial valet sprinkler system
Gary
Dec 14, 2010 | Garden
Garden Logo
1,002 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
