Question about Kenmore 62602 Electric Dryer
Sire88@gmail.com My dryer turns but does not dry.
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 16, 2010
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
Takes too long to dry
Is it heating up at all? I just fixed my vision hd hoover 381 dryer by replacing the heating element. Email me if you think this might be you (matskm@gmail.com). When the dryer is running, feel the metal heater housing (carefully) on the back (silver bulge) if your model is like mine.
Jan 09, 2014 | Hoover VHC391 T-80 Dryer
Azb 9750
If the motor doesn't turn then the bearings have dried up and it seized. As this point the start winding likely overheated and it would blow a thermal cutoff inside the motor as well. Replace the motor.
Nov 25, 2013 | Whirlpool Dryers
I have an LG DLE0442W and its having some problems. Well first to turn it on you have to hold down the power button or the lights will just flicker and it went turn on. When you hold it down it turns on no...
I suspect two issues
1. Need new power button. Easy fix. Check out repairclinic.com or appliancepartspros.com for how to videos and parts.
2. Your sensor strips in dry my have either lint under them or dryer sheet residue on them throwing off the moisture sensor reading and shutting down dryer early.
May 07, 2017 | LG Dryers
Dryer element turns on for a few seconds, then turns off. Clothes take forever to dry.
disconnect vent tube, run dryer...Here is a website that will assist you further:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Mar 03, 2011 | Maytag PYE2200 Dryer
Clothes not dry but dryer turning. cleaned out
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 09, 2010 | Roper RGX4634KQ Gas Dryer
Dryer unevenly drys clothes
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
Jun 21, 2010 | Bosch Nexxt 500 Dryer
Whirlpool washer takes long time to dry clothes.
A dryer ( Whirlpool ) , either heats or no heat . If it heats , then the vent is partially clogged , either in the hose , or between the dryer and the outside . Disconnect the vent , and dry a load , checking the air flow . If good , then to the outside is restricted .
Mar 04, 2010 | Whirlpool LEN2000PW Dryer
Kenmore 62602 Electric Dryer Logo
32 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
