Question about Mitsubishi WT-46807 46" Rear Projection Television
Mitsubishi model Wt-46807 Power shuts down after turning on. Tried the solution of pressing the menu & input buttons at same time for at least 5 seconds. Power light error code was 2 blinks/pause 2 blinks/ pause continously. How can I fix? Please help can't afford new tv now. Thanks, Diane
  • 2 more comments
  • Dimackee Oct 16, 2010
    Please help with locating the "PICO" fuses. The left side of the diagram inset is cut off.
    Thanks,
    diane
    Also are pico fuses removeable or soldered in fuses
    I was able to locate Green in color pico fuses marked F9a02, f9a04
    I don't have a multimeter. How do I check if fuses are bad? Please email detailed instructions to Dimackee@hotmail.com on how to solder or replace fuses. How can I get to the circuit board easily/ It won't slide out/
    thks
  • 10,594 Answers
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Oct 16, 2010
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Oct 16, 2010
    Pico fuses has circuit location number so find F9A04 and F9A05, these are +24V and -24V fuses.
    Above picture is complete as I tried to show tv chassis. Below is bit detailed exploded view and area marked to locate above fuses, in fact you will see few more fuese like F9A02, F9A03 etc there so check them all with multimeter.
    Thanks.
    Pico fuse is soldered in circuit board and soldering work is required to replace them.
    It is not safe for you to involve yourself in tv repair if you have no knowledge, experience or necessary tools like multimeter, soldering iron etc
    I would recommend to have friend's help who has done that sort of work before. I gave you info about problem and its solution and it is not possible for me to send you minor details.
    Thanks.
SOURCE:
Audio but no picture mitsubishi wt-46807
Did you try the OPTION menu---think I offered that to you a few days ago......
Mar 27, 2012 | Mitsubishi WT-46807 46" Rear Projection...
Screen shuts off shortly after turning on
Do the self check this model has, when green power light comes on and then goes out on the front of the set press and hold both the Menu and Input (device) buttons at the same time for at least 5 seconds, then release both buttons and watch the power light, It will blink a two digit code, a error code.
Most common is 2 blinks, 2 blinks, a pause and then it will repeat the code several times.
Let me know what code you find and I will tell you what it means.
This is a self check meant to narrow down what kind of problem the set has.
Make a comment here so I can help.
SD TECH
Jan 15, 2011 | Mitsubishi WT-46807 46" Rear Projection...
My Mitsubishi WT 46807 will not power up. The green light on the front stays on for approximately 2 seconds and then goes out with no audio or visual. I tried unplugging the set for about 15 minutes but...
yes!
When you turn set on and power light goes out do the self check this set has.
On front of set when light goes out press and hold both the Menu and Input (device) buttons at the same time and hold both for at least five seconds and then release both.
Power light will blink a two digit error code like 2 blinks,2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means. Make a comment here and I will assist you.
SD TECH
Nov 27, 2010 | Mitsubishi WT-46807 46" Rear Projection...
I have a mitsubishi wt-42315. when i turn it on it shuts down right away. any thoughts?
Do the self check this model has.
When you turn it on and green power light goes out:
on front of set press and hold both the menu and input (or device) buttons at the same time for at least 5 seconds and release both buttons.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what problem is.
If this helped rate this solution as very helpful as I do this here for free.
SD TECH
Sep 20, 2010 | Mitsubishi WT-42315 42" TV
Turns off immediately after turned on
Do the self check it should have: when shuts down and green light goes out: On the front of the set press and hold both input and menu buttons at the same time for at least 5 seconds and then release both.
Power light on set should blink a two digit error code: like 2 blink,2 blink, pause and repeat it at least 5 times total.
Let me know what error code and I will tell you what it means.
If this has helped you, rate this solution as I do this here for free.
SD TECH
Aug 15, 2010 | Mitsubishi WS-55809 55" Rear Projection...
When i turn it on it shuts right back off
Please do the self check this set has:
When the power light comes on and goes out press and hold both the MENU and Input (also called Device) buttons at the same time for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means and what may actually be the problem.
I am here to help people.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 16, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Does the Mitsubishi WT-46807 need a converter box to receive a HD signal?
Yes, this model only has one HD input--it is the one marked on the back of the set as DTV---you need to hook a box for HD to that input.
SD TECH
Oct 23, 2009 | Mitsubishi WT-46807 46" Rear Projection...
When I turn on my tv it will shut off
Model number is WT-46809?
If set comes on for a moment and then goes off(green power light)
ON THE FRONT OF THE SET PRESS BOTH menu AND input at the same time and hold both buttons in for at least 5 seconds---then release both buttons.
Watch the power light---it should blink a two digit code---ERROR CODE---
The most common is 2 blinks, a pause and 2 blinks-----set will repeat the error code about 10 times.
If you find this error code let me know the blinks and I will tell you what it means and may be able to tell you what is needed to correct it.
SD TECH
Oct 20, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Loss of convergence on the edges
Yes, first do the self test by pressing input/device button and menu at same time for 5 seconds and read error codes by blinks. more info ctechnicians.com
Jan 01, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
765 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
