Question about Canon PIXMA MP600 all-In-One InkJet Printer
Change of printerhead Pixma 600 - Canon PIXMA MP600 all-In-One InkJet Printer
  • 6,993 Answers
Remove the Print Head:
  • Turn on the printer. Lift the top cover.
  • Open the paper output tray at the front of the printer. Pull down the inner cover to open it.
  • Press the tab of the first ink well to unseat it. Lift it up and back to dislodge it, and remove it from the print head. Repeat for the other four ink wells.
  • Raise the print head lock lever on the left side of the print head.
  • Lift and pull out the print head.
Install New Print Head:
  1. Remove the new print head from its packaging.
  2. Hold the print head on its sides. Slide out the orange protective cap on the print head. Do not touch the electrical contacts or the print head nozzles.
  3. Insert the print head into its holder.
  4. Lift and close the inner cover. Reinsert the paper output tray if you wish.
  5. Lower and close the outer cover.
Good luck.
Posted on Oct 16, 2010
How to make printer print
Take the print head on and gently tap the nozzles on a paper towel.If you see all the colors and black then unplug the printer after the printhead is out and the carriage travels to the end (capped0
Wait 30 minutes and re-install the head.
This hopefully will make the printer believe it is a fresh unit
Aug 21, 2014 | Canon PIXMA MP610 InkJet Printer
Where can I buy a printerhead for PIXMA iP4300
newegg.com offers cheap cartridges for PIXMA iP4300, and their shipping is, generally speaking, ridiculously low.
May 06, 2011 | Canon Office Equipment & Supplies
Problem with the printerhead
After a while you need to change the cartridges even if it worked with refill.
Jun 10, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Will not print---all I get is a blank paper
Try to check the ink of your printer that they have more ink inside. Or els just check the printerhead of that printer its maybe that was a problem for that. If they could not print at all after this solution just change your printerhead it is because that was the problem. If your printer are using the built-in printerheat from the cartridge just replace the cartridge of what color are did not print but if your using separate printerhead of your cartridge just only replace the printerhead only.
May 27, 2010 | Dell 926 All-In-One InkJet Printer
PIXMA iP3300 InkJet Photo Printer: my canon iP3300 has an alternately flashing green ...
I may be that your printerhead passed away. A replacement might do the trick.
May 07, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
I cannot determine which pattern is the one with the least amount of streaking during alignment of printerhead
it is not active to print your cartridge change black cartridge or color then solve your problem
Jul 13, 2009 | Canon PIXMA iP1600 Printer
PIXMA MP 600 PRINTER EVERTNING PRINTS GREEN
Usually I see that when you put in photo magenta when it should be plain magenta.Otherwise you need a new printhead.
Jul 03, 2009 | Canon Pixma MP600 Printer
Printerhead is not installed.
What you will need to keep in mind is that the ink cartridge contains liquid ink, once opened, can and will evaporate. First, wash you hands with soap and water to remove excess finger/hand oils. Use a clean, moist, paper towel, make sure you ring out the excess water from the paper towel before you begin. Remove cartridge, gently wipe the towel over the contact's pad, and the nozzel tip. Use a dry towel, and patt dry, reinstall. and run an alignment pattern test.
Note: If you do not see an ink trail on the paper towel, The Ink has dried up, and you will need to but a new cartridge.
Note: do not touch the Cartridge GOLD contacts, with your fingers, finger OIL will clog the jet pours, and cause them to corrode.
May 07, 2009 | Canon PIXMA MP610 InkJet Printer
Canon Pixma 600 printer showoing a green streak
You may running out of the colored ink.. just make sure you change it before it runs out.. make sure you buy a colored ink for Canon Pixma iP1600.. the cartridge of the colored ink of your printer has a number infront of it.. eg: Canon CI-41
Sep 21, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
123 people viewed this question
old marine
old marine
