Question about Taxan Ergovision 735 TCO 99 17" CRT Monitor
Out of Range error
I am an experienced user on my 8th PCand have just purchased a MATROX TripleHead2Go Digital Edition box to enable me run three screens off my nVidia 8800GTX Grahics card when gaming and flight simming. I am using a mixture of CRT and digital monitors which the MATROX supports. My taxan 17" on the left, a MIRAI 22" wide screen digital flat screen in the centre (my best display) and a DEll 19" CRT on the right. My OS is VISTA Ultimate Edition and I am using quad-core CPU with 4 GB RAM.
All 3 monitors power up OK and show the BIOS start up logo across all 3 screens, so I know all are working correctly and in cocert. However, when windows opens I get it only across the centre and right screens and an "Out of range" error on the Taxan.
I am assuming that the resolution of the triple display is currently set too high for the TAXAN to handle and if I simply reduce the resolution it should work. Is this correct?
  • 66 Answers
In my experience lowering the resolution will fix "out of range error"
yes, you are correct
Posted on Jun 03, 2008
Bank charge 7.99 for the last three months
Have you gone to your bank to discuss it with them?
Apr 12, 2015 | Computers & Internet
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
How to print database in vb
To Print a Database you would require to create a Report. There were many ways of creating reports in Visual Basic 6.0. Hereby I am giving you an example of Data Report.
Printing a Data Report
Printing a data report can be accomplished in one of two ways. The user can click the Print button that appears on the data report in Print Preview mode (using the Show method), or you can programmatically enable printing using the PrintReport method. If an error occurs during printing, trap it in the Error event.
Choosing to Display a Print Dialog Box
When printing a report programmatically, you have two choices: to print by displaying the Print dialog box, or by printing without displaying the dialog box.
To display the Print dialog box
  1. Add a CommandButton to a Form.
  2. In the button's Click event, place the following code.
DataReport1.PrintReport True The Print dialog box allows the user to select a printer, print to file, select a range of pages to print, and specify the number of copies to print.
Note Printers must be installed on the computer in order to present a choice of printers.
Printing Without a Dialog Box
In some cases, you may wish to print the report without user intervention. The PrintReport method also gives you the option of selecting a range of pages to print, either all, or a specified range.
To print without displaying the dialog box
  2. In the button's Click event, place the following code:
DataReport1.PrintReport False
Or, to specify a range of pages to print, use the code below:
DataReport1.PrintReport False, rptRangeFromTo, 1, 2
Mar 11, 2014 | Microsoft Visual Basic 6.0 for PC
I just purchased a Matrox DualHead2Go Digital Edition for my MacBook Pro. I have followed the installation instructions correctly (to the best of my knowledge) and I can't get the external displays to...
http://www.opendrivers.com/driver/290211/matrox-dualhead2go-digital-edition-software-utilities-1.01.00.005-mac-os-x-free-download.html
I suspect that you didnt install any driver for it ..and this may cause the issue..This is not a plug and play device and need a driver to work ..If you do not have a driver for mac on the disk here is something that may work ..download it ..and run it ..and after that try to configure from the software ..It may be needed to lower the resolution to a max of 1360/768...but for a normal 19 inch monitor ..it will be enough 1152/864 ..this will be the best choice ..
Jan 01, 2011 | Computers & Internet
Looking for manual
here is manual: http://www.matrox.com/graphics/media/pdf/products/gxm/en_triplehead2go_guide.pdf
Oct 25, 2010 | Matrox TripleHead2Go Digital Edition ...
I have matrox triplehead2go digital edition. Quit working.
Try a different USB port.
Have you checked the hardware in Device Manager? Look for Universal Serial Bus Controllers; check for RED X's.
Make sure all Windows services necessary for USB to function properly are running.
Google any errors, if found, Check event viewer for errors in RED.
Look for legitimate sites like Microsoft, Fixya, forums for similar hardware, Operating system and similar problems.
Sep 27, 2009 | Matrox DualHead2Go (D2GA2AAJ) VGA Video...
Cant get into yahoo canasta
Try clearing out your browser cache first.
Double-check that Java and JavaScript are fully enabled in your browser:
Click "Tools" in the menu bar, and then select "Internet Options."
Click the "Security" tab. For the Internet zone, be sure that the Security level is set to "Medium" or below. (If you have chosen to customize your security settings for the Internet zone, be sure that under the Java heading, "Java permissions" is not set to "Disable Java." You will want to select one of the three safety levels instead. Also be sure that under the Scripting heading, "Scripting of Java Applets" is set to "Enable" or "Prompt.")
Next, click the "Advanced" tab.
Scroll down until you see the sub heading "Java VM."
Check the boxes next to "Java logging enabled" and "Java console enabled." (Note: If you checked the box next to "Java JIT compiler enabled" and are experiencing freezing problems, uncheck that box.)
Note to Windows XP users
Mar 14, 2009 | Computers & Internet
No TV using Matrox G200MMS with WinXP
you need to get rid of service pk3
it may work on pk2
Jan 20, 2009 | Matrox Millennium G200 MMS Quad TV (32 MB)...
Taxan Ergovision 735 TCO 99 17" CRT Monitor Logo
210 people viewed this question
Top Taxan Computers & Internet Experts
David Payne
David Payne
Are you a Taxan Computer and Internet Expert? Answer questions, earn points and help others
