Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Replaced bulb last nite, green light blinks for a min. then it worked! watched a few min.turned on this morning blinking.... wont stop green blink. last nite when i changed bulb tv said change bulb reset something or other by using the remote/ couldnt do it , dont have a remote... changed channel it went off. do i need to reset or can i, w/o/a remote,, or what ?
  • 1,548 Answers
Many projectors use a lamp hour timer for predicting bulb life so they can give you fair warning of impending failure. Since a bulb may be removed and reinstalled because it is still working or another used lamp installed, the timer is not automatically reset to zero when the lamp is replaced. I surmise your set is complaining because the timer was not reset or the time verified when you changed the bulb.
To fix the problem, buy or borrow a remote control; a universal remote control with a menu button may work. (If you borrow a universal remote from a friend, be sure to record the code for your friend's TV first so you can set it back before returning it.)
You could probably get back into the timer reset menu by removing the new lamp and reinstalling it. Caution: follow the directions on page 68 of the user's manual or the sheet that came with the bulb - let the set cool for an hour first, unplug, and wear gloves when handling the bulb since skin oil can cause discoloration and possibly an explosion when the bulb gets hot. You can download the user's manual from Panasonic's support page for this set.
If you can edit the timer hours instead of just resetting, you may want to set it for the number of hours the new bulb has been used.
It is likely that you can get into the lamp timer menu if the set is in service mode, but the user's manual doesn't tell how to get there (I don't have that info either - it's in the service manual, which may be available online from a third party for a price). Usually it is something like holding a volume or channel button on the front of the TV while turning it on with the remote control. After that you need the code to switch to the timer menu. If you have problems getting into the timer menu, ask your dealer's service department or try calling the Panasonic help line listed on the bottom of page 68: 1-888-VIEW PTV(843-9788).
Posted on Oct 16, 2010
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
Broksonic Flat Panel TV, tried to turn back on TV and Green LED light is blinking and screen pops up a few sec with white and colored lines and the turns off
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 21, 2014 | Broksonic Televison & Video
Sony bravia KDL-37XBR6 wont turn on at all, and blinks 6 times..
The 6X blink code is a bad back light error. could be one of the florescent bulbs in the panel if it shows a picture for a couple seconds and there is a darker band across the screen. Also Found loose connector CN6153 on the G5 Power Board.
CN6153 goes to CN6702 on the D4 board. Or the power board
Mar 30, 2012 | Sony Televison & Video
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Projector problem
I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
Jun 20, 2008 | InFocus ScreenPlay 4805 Multimedia...
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
297 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
