Question about Frigidaire GLMV168K Microwave Oven
Nothing works at all just stopped altogether is there a fuse somewhere that might have blown
  • ze_us22 Oct 16, 2010
    do i have to take the microwave off the wall or can i just remove the bottom panel
    Problem Solver:
  • 5 Answers
YES INSIDE MANY OVENS HAVE A FUSE..UNPLUG B4 DISSASEMBLY.
Posted on Oct 16, 2010
  • cooterndeb Oct 16, 2010
    IF THE OUTTER SHELL ATTACHED FIRST TO THE OPENING, YES, UNDI=OING THE BOTTOM PANEL MAY AFFORD YOU ACCESS. BUT REMOVING IT FROM THE WALL, MAY BE THE EASIEST WAY TO GET INSIDE IT.
SAMSUNG MICROWAVE FAN STOPS WORKING. COULD IT JUST BE THE FUSE?
I would guess, I do not know for sure that the fa motor seized and blew the fuse, during the process the internal protection device on the fan motor opened giving you exactly what you are describing.
Nov 27, 2014 | Samsung Microwave Ovens
Whirlpool over the counter microwave stopped working
SEE THE steps and fix it. and diagrams attached.use the DVOM.God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown2_6_2013_8_43_03_pm.gif2_6_2013_8_43_37_pm.jpg
Feb 06, 2013 | Microwave Ovens
My M4155sp stopped working. No power at all (yes, I checked the power source). Replaced the fuse behind the keypad, - still nothing. Any suggestions?
please see the next step: God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
see the diagram attached.
Jul 26, 2012 | Whirlpool MT4155SP Microwave Oven
There seems to be no power. No clock. no nothing. It was working fine and then jut stopped. Circuit is not tripped. I tried unplugging and plugging again.
most likely you will have to remove the louvers or trim above the cooking cavity to get to the fuse, look for screws holding the trim/louvers on, if no screws are apparent, the piece may slide to the left or right and pop off.
Unplug your microwave. Although it might seem like no electrical current could possibly be running through your appliance, it could still have stored electrical current somewhere in the system. Be safe rather than sorry and unplug it before you begin.
  • 2
    Find the wiring diagram for your model of GE microwave. You can contact GE directly to get this if you cannot locate your owner's manual. Note the fuse locations and get a screwdriver. Some GE fuses are located under the louvers, while others are located in the door.
  • 3
    Open up the microwave and locate the blown fuse. Sometimes you cannot determine a blown fuse by visual inspection so check it with a multimeter for continuity across the terminals.
  • 4
    Replace the blown fuse. Go to your local hardware store and pick up a matching fuse. Make sure you check the model numbers of the fuse as well to be sure you get the right component. Install the new fuse and put everything back together.
  • 5
    Check the continuity of the circuit if you continue to have power problems. If you have a problem with continuity in the circuit, then you may have a bigger problem than just a blown fuse. Sometimes a power surge will fry a GE microwave's circuit board, which you will need to replace.
  • Dec 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Hi! Our GE Spacemaker microwave (JVM241BL) stopped working..... nothing on it works at all. We have checked the breaker box in the basement and made sure it is plugged in. We are assuming it is a fuse...
    Turn off the power before starting this process. If the oven is dead, the fuse is probably blown. Remove the two screws that hold the touch pad and control board in place to access the fuse. Once inside, look towards the back and follow the power cord that enters the rear of the microwave to the fuse. It should be a 15 amp ceramic fuse.
    Dec 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
    My spacemaker stopped working and no panel lights. It's not the circuit breaker. Any ideas? model JVM140001
    Could be the fuse inside the microwave is blown. You will need to unplug the microwave and remove the front control panel. Inisde the microwave housing you will need to trace the electrical wire coming into the unit. Usually you will find the in-line fuse located on the black power wire. You can pull the connectors off the fuse and test it with a continuity tester. If the fuse is blown replace it but make sure you use the same amp rated fuse as you removed. If the fuse blows again then there is an electrical short somewhere in the microwave.
    Dec 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave stopped working when i pushed the start button
    Yes. The white inside the glass that you are describing is a blown fuse. To find out what size fuse it is look around the base or top of the fuse. You will see engraved something like "125V 5A. You can pick these up at Home Depot or Lowes in the electrical isle. You can also type www.google.com and enter the word "fuse" and then the size it is. (125V 5A) If you have found this information at all helpfull, please rate my solution. Thanks D. Lange
    Apr 23, 2009 | LG Microwave Ovens
    My emerson microwave has stopped heating up but appears fine
    Hi
    If your microwave oven doesn't seem to work at all, check these:
    Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
    Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
    Please do rate the solution as "FixYa" if found useful and revert for further assistance.
    Thanks
    Rylee
    Mar 31, 2009 | Emerson Microwave Ovens
    Microwaved a sandwich from Wendy's-apparantly it had tinfoil wrap
    There is fuse in the back somewhere around where the cord comes into the unit.My guess the fuse is blown
    Mar 15, 2009 | Kenmore 62622 Microwave Oven
    Frigidaire GLMV168K Microwave Oven Logo
    42 people viewed this question
    Top Frigidaire Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
