Question about Bachmann James The Red Engine Train Set
I put the liquid smoke and no smoke comes out..First i put a couple drops and nothing came out then i put half a tube and still nothing comes out!!
How do I get smoke to come out of my smoky mountain ho locomotive
You have to take the screw out of the top of the smoke stack closest to the cab and put in about three drops of 3-in-1 oil. Put the screw back in and try it. If that doesn't do it replace battery/s. If that doesn't work either, the engine switch may have been left on without any smoke liquid in it and may have burned smoke unit out.
Dec 07, 2017 | Crafts & Hobbies
How do you know if the ac compesser is good or not on 01 s500
refridgerant should NEVER be added to a system thats not running in on posisition ( says so right on can) , there is a multiude of failures that could come from doing this , belt failure's , hose failures, rec tank opening
evaporator coil openings , pump failures
i suggest getting a professional to look at it to see what dammage was done
remember laws of physics 101: Liquids don't compress but gasses do and it takes very little liquid in a gas system to destroy the parts of system
May 13, 2014 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Smoke will not come out of harry potter O gauge engine after filling the smokestack with smoke oil
I think you hit the nail on the head with your own question. "filling the smoke stack with oil". Turn the unit upside down and drain COMPLETELY all oil in the smokestack. Generally only a couple of drops are needed. Those drops will smoke until they quit. A couple of drop should smoke at least 10 minutes or more.
Dec 13, 2013 | Lionel 8141-50 Smoke Unit
98 dodge intrepid 3.2 liter car runs great, full power, not smoking, but has a clicking-ticking noise as it idels. ( sort of sounds like there is no oil but the oil is fine) Wondering if it could be the...
right heres a right nice fixya answer ,put half a pint of diesel into the engine oil with a 3 x2 second squirts of fairy liquid ,not the cheap brand X ,then run car a couple of days and you will find the noise stops ,now change the oil and filter then change the oil every 6000 miles with a filter every third oil, change ,use the cheapest detergent oil for a petrol/diesel engine you can buy .
Nov 21, 2010 | Dodge Intrepid Cars & Trucks
Gas smoker
You'll do better by soaking them for 30 minutes to an hour.
For a unique flavor put a few drops of liquid smoke in the water.
Apr 21, 2010 | Masterbuilt 20050106 Propane Smoker
How can I remove a lodged oil dip stick? Top part of grip has broken off. Someone tried to remove it but lodged it in further down.
Needle nose plyers.
If those wont reach in far enough - you might have to remove the dipstick tube..
Jul 22, 2009 | 2004 Nissan Sentra
I dont know how to put the sea form in my vacum line or were its at.i know to put half in myc tank.someone told me to put half in my tank,and half in my oil.but i just want to be safe then sorry.need help...
I can assume that you mean Sea Foam, the motor treatment. The stuff doesn't work particularly well, but it does pump a lot of smoke out your tailpipe.
They claim that you can dump 1/3 in the crank case (like adding oil), 1/3 in the fuel tank, and 1/3 through the intake. You don't have to do it through the intake, but here's how:
Locate your throttle body (where your air filter leads to - if you need help finding this, have someone step on the gas with the car off, you'll see a cable) Here you'll see some wires and some tubes.
Trace one of the tubes to a clip or junction on the firewall and unclip it with a pair of pliers.
Insert a funnel into the tube, start up the engine (it will run horribly) and slowly add the Sea Foam over the course of 2-3 minutes. If the engine tries to stall out, give it some gas (you can twist the throttle by hand, remember that cable that moved when someone stepped on the gas?). You should see some smoke come from the tailpipe, this is normal.
Rev up the engine - not too high! Keep doing this until the smoke stops pouring out of the tailpipe.
Don't forget to reconnect your vacuum line.
Apr 13, 2009 | 1995 Oldsmobile Achieva
Cant remove oven light cover
Try a adjustable car oil filter wrench (cost a couple of bucks at Wal-Mart). Simply put it around the glass cover and give it a twist. Worked great for me.
Nov 12, 2008 | Ovens
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
Bachmann James The Red Engine Train Set Logo
143 people viewed this question
Top Bachmann Crafts & Hobbies Experts
Andrew Taylor
Andrew Taylor
Steve
Steve
Tom Chichester
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
