Question about Ovens
Viking Elect. oven Mod# VESQ107CSS Set temp to 350* won't hold temp unless you turn it up to 450-500* Is there a site that I can go to to purchase parts for this piece of S##T.
  • Jerry Kerns Oct 16, 2010
    Could this be a thermostat problem?
  • Jerry Kerns Oct 17, 2010
    Thank you but sears doesn't show this model.
  • 560 Answers
Your problem is probably a faulty thermostat control . However , before I direct you to the website where you can order a new one, I would like to check one thing first . Open up the oven door and look towards the rear of the oven compartment for the temperature sensing bulb and metal line that connects to it. Make sure it is mounted correctly in the metal retainer. If it is , then I would suggest replacing the thermostat control assembly . However , if it is not, secure it in its mount clip and try the oven again .
Visit Sears parts direct .com to order a new temperature control.
Posted on Oct 17, 2010
  • 1,711 Answers
  • espressonist
    espressonist Oct 17, 2010
    From your description we thought that you have specified the part.
    Yes all the indication are showing that you need a new thermostat.
My Kitchenaid Oven doesn't allow me to set a temperature higher that 350 degrees. Electric oven. For example, i will punch in 425 and the panel will default back the temperature to 350.
350 will be the design max for your oven unless the handbook says for your model is higher rated and is faulty
repair or replace with a higher rated temp oven
Nov 07, 2016 | KitchenAid Ovens
Erratic temperature on Viking oven
What is the complete model number of your unit?
Feb 18, 2013 | Ovens
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and Fixyourboard.com can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
info@fixyourboard.com
Whirlpool Oven Wont Increase Temperature Stuck at 350
May 27, 2017 | Whirlpool Ovens
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
Frigidaire oven is slow to heat then exceeds set temp set
Normally you should have an appliance spare parts supplier in your area. They generally stock all range of spares for all appliances. You need to pull plug out of the wall and remove the panel covering the wiring to gain access to the oven thermostat. Look carefully on the body of the thermostat and record any numbers you see on a sticker that's present. Then remove knob off in front of thermostat and see if there is a nut attached to the centre which holds the thermostat in position or if there are 2 screws holding the thermostat in place. Use this information to order the thermostat also quoting the oven model number.
Oct 06, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not reach full temperature
Are you checking with a store bought thermometer or your recipe. If it is your recipe then ur thermostat might need a calibration or need to be changed completely if it is really off by more than 100 degrees. If it is 99 or less a simple calibration may just do it. If you have a steady hand. With your thermometer inside the oven and the door closed set at 350. Then take the oven knob off and take a small flat screw driver (really small). And insert it in the valve part where the knob was. With a flash light u can see the small screw. Turn it a hair at a time (1-2mm). Wait 20 minutes and see if the temp does rise. If not turn another hair. Repeat until 350 is reached. You must wait the 20-30 minutes for it to reach the temp. If all else fails changing the thermostat would be next. I do not recommend u do this alone. approx cost is: $400 - 500 front access, 500 - 600 rear access Good luck.
Sep 04, 2009 | Viking Ovens
Doesn't get as hot as it should
the range has two thermostats one for each oven located under the oven knobs. put a meat thermometer in the oven and adjust the thermostat screw with a small flat screwdriver untill the oven turns off at the correct knob temp.
registered on the thermometer.
then adjust the knob screw on the back of the knob to match that temp setting.
clockwise is hotter counterclockwise is cooler
Apr 21, 2009 | Ovens
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Ovens Logo
52 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
