Question about Frigidaire Affinity ATF7000E Front Load Washer
FINLUX WASHING MACHINE DOOR WON'T OPEN WHEN THE WASH IS DONE
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Posted on Sep 21, 2008
SOURCE: My washing machine door wont open
Hello, I have the same problem with mine. I tried the extra load - nothing. I called LG who said unplug and leave for 15min as it tends to lose its memory and needs to be reset. No luck. Did another wash and tried again, nothing. It's still under warranty, but noone can come to look at it for a week and if I get anyone else out, the warranty isn't valid... If anyone has answer, it would be great! Becca
Posted on Sep 05, 2006
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
gittos73
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
FitzOriginal
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
How do I drain water from my finlux washing machine
many finlux machines have an easily removable bottom panel. Once removed there's a pump and drain hose assembly, usually in the front right side. Some have a plug that screws out, others you'll have to remove some hose clamps. It is common for debris like coins, hair clips, paper or what not that plugs the drain. Hopefully this is it, and you'll get a little pocket change.
Feb 01, 2016 | Washing Machines
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
Front loader washing machine door won't open
try unplugging the machine to reset it.
Feb 27, 2012 | Samsung Washing Machines
Thor front loading machine door won't open.
Please check the link below to see how the door can be opened. Once this is done the program controller section must be checked for proper cycle of the functions.
http://www.espares.co.uk/advice/washing-machines/a/7/1294/how-to-open-a-washing-machine-door-thats-stuc.html
Aug 22, 2011 | Washing Machines
I have a Finlux 146J washing machine and am having problems with the conditioner. It is no longer going into the machine. I have only had the washing macine 6 months but am unable to fins the manual for it
Finlux 146J washing machine and am having problems with the conditioner This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jun 07, 2011 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
96 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
