I have a rear projection TV 50" TN50X81. The unit will frequently turn off for no apparent reason, and unable to turn back on for awhile. It seems that maybe when it reaches a certain temperature, it turns off, then must cool down again(?). Thank you.
  • raytiede Oct 16, 2010
    ok, thank you. I will open the unit up and do as you suggest.
    Genius:
  • 1,622 Answers
All you have to do is to open the back cover of the television to check for dry soldering, bulged capacitor, You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some resolder where necessary, but if otherwise the power board is bad. you can check on ebay.com, shopjimmy.com for a new power board for the television.
Hope this help in solving the problem.
Posted on Oct 16, 2010
Toshiba TN50X81 50 TV
More likely is the set is in shutdown---most common issue on this type of set is the convergence---to know you would have to locate and unsolder both 18 pin convergence chips---with them out of the circuit if the set comes on (will not look good) one of the two chips is shorted--these sets have very good protection circuits to prevent many parts from being destroyed at one time..
These are the chips--STK number is right on the front.
May 25, 2012 | Toshiba TN50X81 50" Rear Projection...
Television will not turn on - power light blinking
i have seen before that model have pretty severe cracked solder connections on the power board. otherwise those types of tvs can have convergence failures that will keep the tv from turning on.
Jan 06, 2011 | Toshiba TN50X81 50" Rear Projection...
I have a Toshiba TN50X81 Cinema Series HD the sounds works great but there's no picture. It just went blank all of the sudden. Opened it up and there's 3 bulbs and none of them are working. Can anyone...
the bulbs go out it is normal on projection tv's, you can order the new one online, just out in the model number of your tv and you will find it, be very carful not to touch the bulbs when they come or when you are putting them in the tv
Aug 11, 2010 | Toshiba TN50X81 50" Rear Projection...
No picture after replacing convergence ICs on TN50x81
You likely have shorted soldering. If you bought a kit from someone go back to their site and ask for help.
Jan 16, 2010 | Toshiba TN50X81 50" Rear Projection...
Convergence Issue on Toshiba TN50X81 - Service Manual & Parts Source?
Replace the convergence IC's - P/N STK192-110 with part STK192-150 or 180. Then you can go back in and make the detailed convergence settings and get your picture back in alignement. Also check the flame-resistant resistors around the ICs to make sure that none of them have opened up.
Jan 11, 2009 | Toshiba TN50X81 50" Rear Projection...
TN50X81 - one convergence IC runs hot...TV powers off after 5min
What was the STKs that was in set ? If 110s always upgrade to STK392-180s. If they were 392-560s go back with the same. they worked differently then the 110s 150s 180s
Nov 27, 2008 | Toshiba TN50X81 50" Rear Projection...
Toshiba TN50X81 Power Issue
We had this problem too. If finally got to where it wouldnt turn on at all. A service man came out and replaced the power switch. That took care of the problem.
Feb 23, 2008 | Toshiba TN50X81 50" Rear Projection...
Toshiba TN50x81 50 Inch TV most of the images seem to have a ghost image behind them
Remove the right speaker grill, there you will see some adjustemt knobs, I never tried it but might be helpfull.
Nov 10, 2007 | Toshiba TN50X81 50" Rear Projection...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
