Question about Horizontal OHC Engine 190cc GC Series 34in x 2 716in Shaft M
I have a honda gc190. it starts fine but when the trigger is pressed the engine stouter and cut off
Most likely the pressure relief valve in your pump
Posted on Dec 28, 2010
Govoner arm came off how to put it on in the right place
thats a honda engine
Search Results
Honda Engines ' GC190 Owner's Manual
engines.honda.com/parts/ownersmanuals/gc190 Download or purchase Honda Engine owners' manuals for the GC190.
Honda Engines ' GC190 4-Stroke Engine ' Features, Specs, and ...
engines.honda.com/models/model-detail/gc190 Official specs and features for the Honda GC190 OHC engine. ... is a small four-stroke gas engine designed for premium residential use. ... Owners Manual.
[PDF]honda 6hp gc190 repair manual.pdf
www.publicwalls.org/honda/honda-6hp-gc190-repair-manual.pdf
Apr 08, 2016 | Horizontal Engine 6 Hp Ohc Gc190mha2
Honda gc 190 starts then floods and stops. Wont start again till plug is taken out and dried then repeats same thing
Float level or a sticking needle valve, check float level as if it is adjusted incorrectly it can cause the main jet to allow fuel to flood through, the needle valve can do the same.
Jul 28, 2014 | Honda Engine Gc160 Gc190 Gcv135 Gcv160...
How do you replace the honda gc190 decompression mechanism
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily. The valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Mar 16, 2013 | Karcher 2500 PSI Pressure Washer
Honda GC190 can't pull starter cord
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily then the valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Aug 29, 2012 | Honda Garden
No fuel to spark plug
hi have you checked all the fuel line inc filter for blockages regards
Dec 28, 2009 | Honda Garden
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Aug 13, 2009 | Karcher 2500 PSI Pressure Washer
Horizontal OHC Engine  190cc GC Series 34in x 2 716in Shaft M Logo
441 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Spud Howell
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
