Question about Microsoft Windows XP Home with SP2 N09-00984-os for PC
Have a 1999 gmc small suv truck that will not start-up after checking the timeing and replace rotor and cap also spark plugs with .060 gap.
    Brigadier General:
  • 10,406 Answers
> Microsoft Windows XP Home with SP2 ...
Backup all your files & music & E-mail & contacts to an external device: DVD-writable, USB memory-stick, external disk-drive.
Reinstall Windows, and reload your files.
That should fix any SOFTWARE problems -- if you have a HARDWARE problem (dying disk-drive, bad RAM, et cetera)
that's a separate round of trouble-shooting.
Posted on Oct 16, 2010
Ignition mystery! 1994 GMC Suburban 2500 5.7 mtr. No spark to spark plugs. Have spark from coil to distributor. Have changed coil wire, cap, rotor, ignition module, and coil. have 12.5 volts going to...
I guess you could have the ignition analyzed on an oscilloscope. Maybe a tech could see something then.
I always heard the only gap was the spark plug gap-the rotor has no gap-are you sure you got the correct rotor? And does it touch the top distributor cap coil wire tower?
Let us know. It is a mystery worthy of a solution.
Sep 21, 2013 | Chevrolet Suburban 2500 Cars & Trucks
Spark Plug Gap for 1996 GMC Jimmy
They should be pre-gapped, but you should always check in case someone dropped the box.
The gap is .060
Jul 18, 2012 | 1996 GMC Jimmy
What is the spark plug gap for a 2004 GMC Sierra 8.1 liter V8.
.060 (In thousandths of an inch) Caution! Gap is not adjustable on certain plug brands. Torque the plugs with a torque wrench no more that 15 ft lbs.
Sep 22, 2011 | 2004 GMC Sierra 2500
My car will not start and i recently changed the spark plugs but did not gap them the person told me i didnt need to so im asking you hat is the proper gap cause i think i need to gap them and replace the...
You always have to at least check spark plug gap
In 47 years, I have never seen a set of plugs that were not
knocked around & the ground electrode bent, on at least
a couple of them
You can clean a rotor & cap & get 3 years out of them,
no need to replace until they get too corroded
Wires last 15 years no problem
Don't get caught up in all the hype & tune-up non sense
The gap is on the radiator support label
The coil has to be tested,you don't throw parts at a problem
If it doesn't start, it has nothing to do with rotor,cap,plugs or wires
You could throw away 2 plugs & it would start on 6
Jul 04, 2011 | 1992 GMC Suburban
Engine misfiring.
most all v8's have the same firing order which is 1,8,4,3,6,5,7,2. sparkplug gap seems fine. with the engine off, bend the sparkplug wires between your fingers, if small cracks appear then replace them. number one sparkplug is located at the front driver side of the engine, front to back on this side are cylinders 2,4,6, and 8 respectively. turn the engine to the compression stroke on number one, pull the cap, the rotor points where number one will be.
May 11, 2017 | 1996 GMC Suburban
1996 GMC 1500 4.3L pick-up Spark plug gap setting
look under the hood on the cover on the top of the raditor. there is a decal there and it has accessory belt routing and also the spark plug gap is listed there also.
Jul 26, 2009 | GMC C1500 Cars & Trucks
94 GMC Yukon (No Spark)
Check your spark plugs and see if they need to be replaced. Check the gap on the spark plug. You may have low compression, timing belt or chain should be checked as well. Check the computer system in your car. Is your check engine light on? Maybe your crank sensor is not working properly. Try these and if not get back to me and we'll try more possibilities.
Jun 20, 2009 | GMC Yukon XL Cars & Trucks
Microsoft Windows XP Home with SP2 N09-00984-os for PC Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
