Question about Motorola Mobility RAZR V3
Locked out of phone book
I stored a number without a name, now it will not allow me to access my phone book.
can you help
  • 94 Answers
Its not the problem go into securites and unlock ur phonebook ur code is 0000 and ur securite code is 00000
Posted on Jun 05, 2008
Is there any way to make the persons name appear for a text
It should be as simple as adding their name and number to the address book on the phone.
Make sure to list the number under the Mobile Phone line.
While in the address book, there is usually a line that says "New Entry" or "Add number" etc...(without the type of phone I cant get specific).
Another method is to into the text message itself and do an options click (again without the phone cant be specific) and there should be an option to add the number to the address book.
Aug 05, 2009 | Cell Phones
Can't access anything on Nokia 6300. It locked up and gives message of: (Message storage memory not ready) No Nokia place around to take it to. Please help!
The phone's memory is full, which causes the error message and lock ups. This error prevents you from freeing up memory by deleting messages.
Try the following (taken from the Nokia support forum): http://discussions.nokia.co.uk/discussions/board/message?board.id=hardware&thread.id=7775
1. Delete unused names/numbers from the address book to free up memory. (Perhaps write down the ones you want to keep for later re-entry)
2. Once a critical threshold is reached the msg inbox indicator will blink on
3. Enter inbox and DELETE as many messages as you can before phone freezes up again
4. If phone freezes or you get the error message again, restart and keep deleting from the phone book until it allows you hassle-free msg inbox access as per normal (but don't forget to continue deleting thos messages).
May 05, 2009 | Nokia 6300 Cellular Phone
I have only 26 names stored in the handseet and it
It uses a shared memory. The caller ID and the Phone Book share the same memory. Clear out the caller ID and you will be able to store more names/ numbers in the phone book.
Mar 20, 2009 | Uniden Cordless Phone
Phonebook
If you tell you phone company, they would most likely replace your phone for free if you tell them that its defective. T-mobile does it for sure. Hope I helped. =)
Feb 24, 2008 | Motorola Mobility RAZR V3
Phone book doesnt stay open motorola V3
Press 1 and then # - This will bring up the speed dial info. Scroll through the numbers until you find the one without a name or number and then delete it.
Tada! The phone book will now open again.
Dec 17, 2007 | Motorola Mobility RAZR V3
V3 Phone book
Press 1# then find the number without a name and either edit or delete it
Nov 06, 2007 | Motorola Mobility RAZR V3
Cannot access phone book
haha simple flash back with any flex compatible with your phone SW.
Aug 29, 2007 | Motorola Mobility RAZR V3
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
Phonebook access
i can help... i have incurred this problem a couple of times and understand the frustration! firstly, the reason why snd how this problem occurs is you have saved a number to your phonebook without a name and this causes the phone book to wig-out! to fix the issue simply press "1#". This will allow you to view your phone book in its speed dial order. Scroll through this menu until you find the saved number without the name and DELETE it. This will immediately bring your phone book back to normal. Good luck!
Dec 22, 2006 | Motorola Mobility RAZR V3
Cant access phonebook
your on the right track 1# then scroll through to find the number without the name and either delete it or add a name to it
Nov 07, 2006 | Motorola Mobility V300
Motorola Mobility RAZR V3 Logo
49 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
