Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Pump runs but nothing is pumped out - Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
My SHE45M wouldn't drain. ended up being the pump impeller was jammed with some debris. Removed cover on impeller in drain sump, freed impeller by hand and works perfect.
Posted on Dec 31, 2012
I just had a tech over,have the same problem with my SHE45M. Was told the plastic impeller is spinning on shaft. New to replace the drain pump.
Posted on Oct 17, 2010
Fitted one of your shower pumps when I turn off shower pump keeps running terry
cannot be a fixya pump as the site sells nothing
if the pump keeps running after the water is turned off then it is the pressure switch that is not working
contact your pump supplier if the pump is new or get a new pressure switch
Oct 08, 2016 | Plumbing
Tip
Fuel pump not running
Run a wire from the power side of your fuel pump to the battery have an assistant momentarily touch the wire to the battery and listen for the fuel pump motor to run it sounds like a 4 second buzz;
if you hear nothing your ignition switch is bad if you hear the motor
clean the ground wire to frame connection to the fuel pump.
on Oct 19, 2015 | Miscellaneous
Is the headlight washer pump on the same fuse as the windscreen pump as head light washers are not working
Could be several problems, if you can hear the pump run, but nothing comes out of the nozzles the nozzles could be plugged up or there might be a bad hose. If the pump does not run then get a test light and a helper and see if you get power to the pump when you run the washers. If you do get power and the pump does not run then check the ground, but chances are the pump is locked up. If you do not get power to the pump then get to the back of the switch and see if you have power there. If you have power into the switch and nothing coming out when you activate the switch you need a new switch. If you do not have power to the switch, check the fuse block.
Oct 11, 2014 | Cars & Trucks
Yesterday, I noticed that the Hayward pool sweep wasn't moving, nor was there any water flowing from the outlets in the pool. I cleaned both baskets - nothing. I installed 4 brand new cartridge filters -...
A pump motor running without any flow of water is one of two things. The impeller inside the pump that is connected to the motor is broken or clogged. Open up the pump and inspect the impeller for debris or seperation and clean or replace as needed.
John
Dec 23, 2010 | Hayward Pool & Spa
Gaggia Titanium. Fault suggests ventilation required. Followed manual instructions, nothing happens. Tried rinsing, nothing happens. Tried hot water nothing happens? Have taken out and cleaned all pbvious...
Do you hear the pump working but no water flows?
You should select hot water (the third button from the right) and the display should say "hot water" at the same time it is saying VENTILATE --- open the steam valve all the way and the pump should start and you should see water from the steam wand.
If you don't hear the pump at all, then that is a different problem.
If you do hear the pump but still don't get any water with the steam valve open, then you need to prime the pump by using a turkey baster or the accordian pump that came with the Titanium to pump water into the valve where water from the tank goes. Remove the tank and use the turkey baster to pump water into that valve while the pump is running and the steam valve is open all the way with HOT WATER selected. the second water starts to come out the steam valve you want to stop the pump (turn the power off or turn the steam knob shut) and put the water tank back on and make sure there is plenty of water in the tank - then start the pump again by opening the steam valve all the way and let it pump water out the steam wand for a few minutes.
Oct 05, 2010 | Gaggia Titanium Espresso Machine
The washer filled with water and started washing but now it won't drain, the knob keeps going and then just turns off but the water won't drain..what should I do?
Do you hear the pump run when it is supposed to? If not, then the pump may need to be replaced (warranty?). If the pump runs, but nothing comes out, lower the drain hose to a pan or bucket on the floor to see if water will run out under gravity. If water does come out, the pump may be defective (the impeller in the pump is loose on the motor shaft). If nothing comes out of the drain, look for a pinched drain hose or the hose from the outer tub to the pump. It may also be an obstruction in the drain connection at the tub connection (a stray sock or similar). Hope this works!
Mar 16, 2010 | Tecnik TKL9260 Front Load Washer
The dish washer runs but does not pump the water out sounds like the pump is runing and nothing seems to be plugged
Dec 31, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Turns over won't start
If pump is getting power and does not run, then it would be safe to assume there is something wrong with it or it does not have a good ground. Especially now, with outsourcing to other countries, quality control is abysmal...don't believe anything is good till it is working.
Jul 09, 2009 | 1998 Jeep Grand Cherokee
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
278 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
