Question about Olivetti wireless All-In-One InkJet Printer
I cant locate the position of the ink catridge on the printer. Olivetti any_way wifi
    Brigadier General:
  • 10,406 Answers
Turn the printer on.
Lift the lid that covers the print-head mechanism.
Wait 10 seconds, and the ink-cartridges should "slide"
to the position from where you can see (and remove/replace) them.
Posted on Oct 16, 2010
First computer showed that the black ink catridge not indicats.But it was there and it was new.it was disappeared from the tool moniter counter.we tried to opperate withouit ahe computer connection then...
Needs more inc! a new cartrdige..
But hoever if you can get the old one out you could always try to reset it with a needle or a toothpick..a pen might work..
There is often a moderet amount of inc left due to poor memory in the inc cartridges..
Feb 10, 2012 | Olivetti ANY_WAY simple
Printer will not print saying that the printer is out of ink. Test shows empty cartridges. Took the cartridges to store, they checked and said they were full, doing a test page to confirm. Is there some...
try clean the gold contacts that touches the printer and the catridge.I remember some of the pins tells the printer the leftover ink in the catridge.
the other thing is, hp ink will 'expire'. there is a fixed date stored in the chip of the catridge. if the date is expired, you cant use the ink regardless its full or empty.
Sep 22, 2011 | HP Officejet 5610 All-In-One InkJet...
I need help setting up my ANY_WAY WIFI PRINTER, using the wireless settings. I done it once before about a year ago and had to recover my laptop since and cant remember how I done it!
Hi.
You need drivers and an USB cable.
First install the printer as USB, then follow Activating Wi Fi components. Procedure is detailed from page 9/part 3 of manual below.
Here the manual for Olivetti AnyWay
If you have misplaced the printer disk, then you will need to download the drivers from Olivetti website: CUSTOMER CARE - Olivetti
Sep 13, 2010 | Office Equipment & Supplies
Hi Guys I have a Brother MFC 3360C the problem is i have replace a new Black Ink Cartridge and the machine cant print black anymore it can only do color. What cause this to happen and also what is a...
hi...
as you repalced please check the following.
1.check weather the catridge is been placed correctly and in correct position
2.when you get a new catridge there is a protective cover placed in the outlel of the catridge so please check weather you remoced that protective coating.
3.the outlet may be blocked by the old ink which got dried up. so please clean the outlet of the catridge and try once
if may answer was usefull please vote
Jul 14, 2010 | Brother Multi-Function Center MFC-3360c...
I cant print it is showing e5 on printer screen
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-3
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
CANNOT FIT IN THE REMOVED INK CATRIDGES INSIDE CATRIDGE HOLDER
I located a printer repair service prson locally who fixed the problem, taking printer to his service centre.Now it's OK.
May 05, 2009 | Office Equipment & Supplies
I installed new ink catridges and the little box still shows that the ink is low. it showed now that there is now black ink left, cant print. What do I do?????
i installed rerefilled collor catridges 831 and the little box show that ink is low and 831 ink has run out
what do i do please help me
Apr 15, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Cannot locate ink catridge for HP PSC 750 printer
With power on, simply lift up from the hatch located on the front of the unit. The ink jet will slide to the middle position.
Mar 27, 2009 | HP PSC 750 All-In-One InkJet Printer
How to refill 818 hp ink catridge
make sure u install the catridge in the right way....make sure it clciks into position.....
Mar 07, 2009 | HP DeskJet F380 All-In-One Printer
Lexmark 3470, new ink dosn't work.
In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
Apr 06, 2008 | Lexmark X7350 All-In-One InkJet Printer
Olivetti wireless All-In-One InkJet Printer Logo
60 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
