Dislay has white horizontal lines running through display and the image on screen changes size. It is corrected by taping on both sides of laptop. It apears to be a bad connection, but I have remove keyboard and screen and resetted cables. This seem to fix problem for several days, but the prblem is back
    Brigadier General:
  • 10,406 Answers
> Barcode Scanners
> taping [tapping?] on both sides of laptop.
If it is not a problem with the "data" cable between the motherboard and the video, then it's a problem with the video-adapter circuitry on the motherboard.
Connect an external monitor when you see the "lines".
If those lines also appear on the external monitor, then it is the video-adapter that is generating those lines.
Posted on Oct 16, 2010
What is causing interpolated image shifting on my Sony KDL-403000 LCD TV? It has wide vertical bands of horizontal lines that are shifted parts of the displayed image, only occurring on the sides.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 10, 2017 | Sony Televison & Video
How do i get rid of a horizontal line
It is a bad LCD. It may just be bad timing. Buy a new display on eBay for $50 and look up a video on how to replace the LCD on your particular laptop model. When ordereing, make certain to order the correct display! Matt finish versus glossy and screen size.
Aug 29, 2015 | Acer Aspire V5-122P-0864 11.6" Touch...
Philips 47PFL5609D/30 White screen displays on 3/4 of screen
It sounds that the connection between t'Con board to panel have some problems; loose contact etc. Check it. Re-seat them once, and check. If you wish to get more details about faults to Philips PFL series flat panel TVs, check this link.
Feb 05, 2013 | Philips 47 in. LCD HDTV
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
I have a Compaq Q2009 (new). The picture is too wide on the right side, cutting off the image about 1/4".
There are a series of buttons on the monitor. There's probably a Menu button that allows you to change the dimensions and sizes of your picture on the screen. You'll need to open the picture menu, and find the Horizontal picture options. There are normally two options - one changes the horizontal placement, and the other changes the horizontal size. You can play with these two options until you can see your whole screen.
Mar 07, 2010 | Compaq QVision 171FS (White) 17 in.CRT...
White area in LCD screen with colored vertical lines
LCD needs to be replaced.
Common problemcalled "Tab separation".
Nov 24, 2008 | Acer Aspire 8920-6671 Notebook
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Laptop screen has horizontal white lines running across half the screen
Horizontal lines on bottom third of my Toshiba (Satellite Pro) Laptop with XP windows got fixed by flicking my finger on the laptop screen! Was it a loose connection? I don't know. Change of screen resolution did not help, Rebooting, did not help nor restoring to prior dates. Thank you guys.
Mar 27, 2007 | Dell Inspiron 9100 Notebook
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
