Hiya I have a new laptop (HP Pavilion dv3-2310ea) and the cooling fan is always ON. It's on the highest level and very noisy. BIOS software is not downloadable. The fan is not blocked or dirty as laptop is very new. Please help
    Brigadier General:
  • 10,406 Answers
Restart the computer, and enter BIOS SETUP.
You should be able to adjust the fan-speed.
Posted on Oct 16, 2010
Got noise from fan told its fan on hard drive worn is this fault with them only 2 years old
The hard drive does not have a fan. There is a fan on tht CPU heatsink and a fan in the power supply. You may have a case fan for additional cooling, but this is not always installed.
Noisy fans are easy to replace, but not the one in the power supply.
Jan 13, 2011 | HP Pavilion dv9000z Notebook
HP Pavilion dv6810us fan is too noisy. I have already tried installing all the latest updates (including BIOS), completely disassembled the computer and cleaning it (including the fan), reinstalled windows...
May be you should try changing SMPS and try if it is working.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | HP Pavilion dv6810US Notebook
Laptop fan has a noisy and pc is shutdown after some time ..so can I replace the fan ? pavilion dv3-2175ee
How to Replace a HP Pavilion dv3 Fan?
1. Follow your laptop owner's manual and assembly guide carefully you can download this from HP web site as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, CD/DVD drive and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the HP Pavilion dv3 Fan Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and fan. Replace the screws, plug the HP Pavilion dv3 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new fan running and feel warm air blowing from the vent on the side of the laptop. A HP Pavilion dv3 Fan does not run continuously, so don't be concerned if the HP Pavilion dv3 Fan shuts off periodically.
Jan 10, 2011 | Computers & Internet
I had a pavilion dv4-1430us for over a year, recently I started up the fan was very noisy like a bearing noise. what should I do? thanks for the advice
If you have no experience with opening an repairing computers or laptops I recommend you take the computer to an HP Laptop Service center. If you understand the issues involved you can order a cooling fan from HP and install it yourself as long as you keep track of the screws in the outer case and where they go as well as any cabling.
Nov 27, 2010 | HP Pavilion dv4-1430us Notebook
The HP dv6700 has a noisy fan but the noise
THE CPU IS AUTOMATICALLY CONTROLLED BY MOTHER BOARD. WHEN THE HEAT IS ON IT MOVES FAST AND AFTER COOLING IT WILL GET SILENT. U MAY CHECK IN CMOS SETUP FAN MODE
Apr 15, 2010 | HP Pavilion DV6700T Notebook PC
Looking for procedure to open the back of an hp 8225nr to replace the internal fan. racing up and down and making high pitched noises
You need to goto the HP website and look for the tech manual for the exact model number of your PC. You will need an appropriate size screw driver and make sure you remember where all the screws go! You can lay them out on paper just like you removed them. A noisy fan may just need the dust blown off with compressed air. Most new PC's have software based fan management which may auto-control the fan RPM based on what level of enery or stress the CPU is under while performing an application so the racing up and down may in fact be normal. You should investigate the fan RPM feature of your PC / OS.
Dec 13, 2009 | HP Pavilion DV8225NR Notebook
HP Pavilion dv6449us laptop noisy fan
you may find replacemente in some electronics shops dedicated to laptops spares.
Nov 27, 2009 | HP Pavilion dv6000z Notebook
Overheating
It just could be in an enviroment that is too hot. Try using the laptop on a cool flat surface that does not block the vents in any way while in use. If the problem still persists you have 2 options, 1. Upgrade to a better heatsink/fan unit, or 2. Spend $20-30 on one of those laptop cooling pads and use it whenever you use the laptop. Hope this helps.
Jul 08, 2009 | HP Pavilion dv5-1140us Notebook PC
Noisy fan
hi thanks for using fixya!
I suggest, you bring your laptop to a service center to check further and replace the fan.
Regards!
Apr 26, 2009 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
